Bjur Posted January 18, 2012 Posted January 18, 2012 When I use Recording Service with my smartphone I get 2 Channel Groups. Can I somehow disable it, so when I press program overview for instance I get to view my channels directly instead of having to chooose between 2 groups first which is identical? I have disabled them in Hardware in the Recording Service configuration.. Hope someone can help:) Quote
bogdan1980 Posted January 19, 2012 Posted January 19, 2012 confirm this, its awfull having 2 identical list. Quote
Tjod Posted January 19, 2012 Posted January 19, 2012 You can edit the channel list in the channel list Editor in DVBViewer Pro. Quote
bogdan1980 Posted January 19, 2012 Posted January 19, 2012 (edited) Tjod, something is wrong here. In channel list editor on pc i have this: Scan 17.12.2011, DIgitv on iphone i have: All channels Digitv on Iphone i have 2 lists, on PC i only have Scan DigiTV. You cant edit those 2 iphone channels list on PC, because they exist only one. Edited January 19, 2012 by bogdan1980 Quote
Tjod Posted January 19, 2012 Posted January 19, 2012 Do you have only one Root folder and one category? After editing the channel list you have to restart the recording service to see the effect. Quote
Bjur Posted January 20, 2012 Author Posted January 20, 2012 Please see attached to see what my channel list looks like. It no problem in normal browser but on Ipad it's really annoying to have 2 groups. Quote
Tjod Posted January 20, 2012 Posted January 20, 2012 You have more then one category. In the Root folder Kanaler are 73 channels and in the category Kanaler 38 channels. So there is ad least a second category. Quote
bogdan1980 Posted January 20, 2012 Posted January 20, 2012 For me i have an single list with video and audio. I couldnt not move audio radio to video group. Quote
Bjur Posted January 20, 2012 Author Posted January 20, 2012 Problem is that I can't move the 38 channels up in the Kanaler category... Quote
Tjod Posted January 20, 2012 Posted January 20, 2012 If you have TV and radio channels. You will get at least two groups in the Recording Service. One with all TV channels and one with all radio channels. But you have no identical lists. Quote
