rababo Posted September 19, 2004 Posted September 19, 2004 Hi, I am trying to setup a skystar 2 TV card but with DBViewer I can only receive programs up to 12000 MHz. By performing the scan I see, that no program is found for LNB frequencies of 10600. What could be the reason? Wrong configuration of the software? Or is my Universal LNB damaged? I have connected the LNB directly to the skystar PCI card. Any idea? Thanks a lot, Rababo Quote
admi-ral Posted September 28, 2004 Posted September 28, 2004 do you have a digital-receiver to test the lnb? if that works, the DVBViewer must, too. did you try to reinstall and use the predefined channels? how long is the cable between ss2 and lnb? Quote
Technofriend Posted September 28, 2004 Posted September 28, 2004 Are You sure it is a Universal LNB?? Is the wire to the lnb veery long? Quote
