EPG Single Channel List View?
Lakes
The title says it all, I prefer a single channel EPG list view similar to the old Thomson TIvo (uk) or the Topfield EPG list view, where up/down keys selects program to record and left/right changes channel.
If someone can show show me how to configure the software this way, I will buy it. :)
Thanks.
This is what I see.
And with OSD Menu.
As you can see, I`m not seeing the full EPG and no EPG data at all on some channels.
Ok, I`ve checked "Receive Freesat EPG" now, can I force an EPG data download?
Thanks.
Esc > Program displays:
which is what you want, isn't it?
Edited by SimonP
Yes thanks, gradually working out how to set things up, but I`ll def be buying this software. :)
EPG is loading BTW, so ignore my previous question about that.
Edited by Lakes
