uglyned Posted January 21, 2012 Posted January 21, 2012 Hi, Does anyone else have a problem with blocky artefacts on Channel 4 HD satellite? If I'm using the custom EVR renderer, it doesn't matter what codec I use, I get constant blocking, like BBC HD used to be before ATi updated their drivers. No blocking at all using VMR9. Channel 4 HD terrestrial is fine with either renderer - no blocking at all. I have an ATi card, using Windows 7 64 bit. Has anyone else seen this and managed a fix? Quote
dvbrewer Posted January 22, 2012 Posted January 22, 2012 (edited) Hi, Does anyone else have a problem with blocky artefacts on Channel 4 HD satellite? If I'm using the custom EVR renderer, it doesn't matter what codec I use, I get constant blocking, like BBC HD used to be before ATi updated their drivers. No blocking at all using VMR9. Channel 4 HD terrestrial is fine with either renderer - no blocking at all. I have an ATi card, using Windows 7 64 bit. Has anyone else seen this and managed a fix? Did you try LAV decoder? No DXVA yet, but it is adding next update. Edited January 22, 2012 by dvbrewer Quote
uglyned Posted January 24, 2012 Author Posted January 24, 2012 Thanks dvbrewer - I had a look at this and downloaded the 64-bit version. I've installed it, and I can see and run the programs from the start menu (Win7 64-bit) but none of the filters are available in DVBViewer. I tried linking to the ffmpeg resources linked in post 1, but it all seems to be uncompiled. I couldn't find a simple 'download this and install it' link. Looks very promising though, if I can get it to work. Quote
Tjod Posted January 24, 2012 Posted January 24, 2012 I had a look at this and downloaded the 64-bit version.You need the 32-bit version. Quote
Soupdragon Posted January 24, 2012 Posted January 24, 2012 (edited) You're lucky, I can't get anything at all, just a blank screen. Other HD channels work fine though (BBC1, BBC HD, ITV 1 HD) I probably need to download some custom transponder.ini file, that usually fixes it. As for your general problem it's probably something to do with the AVC codec you're using, the free ones aren't terribly good in my experiance (ffdshow is rubbish at de-interlacing) the pay codecs are better but not perfect (PowerDVD 11, DivX) - if you watch fast motion it's still "jerky" (recorded video plays back fine though) P.S I'm using Win 7 64bit, ATI 4870x2 card. Edited January 24, 2012 by Soupdragon Quote
dvbrewer Posted January 25, 2012 Posted January 25, 2012 Thanks dvbrewer - I had a look at this and downloaded the 64-bit version. I've installed it, and I can see and run the programs from the start menu (Win7 64-bit) but none of the filters are available in DVBViewer. As Tjod says you need the 32 bit as DVBViewer is a 32 bit app. At the moment it will be no better than ffdshow though for ATi/AMD as DXVA is not enabled yet. As for your general problem it's probably something to do with the AVC codec you're using, the free ones aren't terribly good in my experiance (ffdshow is rubbish at de-interlacing) You can enable hardware deinterlacing on ffdshow by ticking set interlace flag on output and NV12 colorspace. Quote
dvbrewer Posted January 25, 2012 Posted January 25, 2012 (edited) As Tjod says you need the 32 bit as DVBViewer is a 32 bit app. At the moment it will be no better than ffdshow though for ATi/AMD as DXVA is not enabled yet. There is an RC for 0.45 with DXVA you could try link (uninstall old version first). Edited January 25, 2012 by dvbrewer Quote
dvbrewer Posted January 28, 2012 Posted January 28, 2012 There is an RC for 0.45 with DXVA you could try link (uninstall old version first). Full release of 0.45 LAV with DXVA 2 copy back is out for ATi/AMD http://forum.doom9.org/showthread.php?p=1554374#post1554374 Quote
Benarty Posted February 11, 2012 Posted February 11, 2012 We had also very blocky video with channel 4 HD(NAR) I re-alligned the LNB's on a wavefrontier T90 with a more accurate satelite alliging tool showing also BER etc... and now chanel 4HD shows stable video but is erratic, sudden frame jumps and DVBViewer works very slow accessing the menus both within OSD as windows menu's. CPU use on channel4 HD (NAR): below 10% on an Intel Xeon 2,2 Ghz dual core, 2GB ECC DDR3 ram, Digital devices cines2 V6 nvidia Geforce GT520 with 1GB video memory. No mpeg blocks tho.Video halts at frequent stages , source not yet known no higher cpu use when this happens and jumps less then a second later to stable video again, audio is always playing fine so obvious video related. This Xeon setup is much more stable then the previous amd setup. I can accept the loss of channel4 HD(NAR) tho. Quote
dvbrewer Posted February 21, 2012 Posted February 21, 2012 Full release of 0.45 LAV with DXVA 2 copy back is out for ATi/AMD http://forum.doom9.org/showthread.php?p=1554374#post1554374 LAV 0.47 has now been released with full DXVA2 "native" acceleration http://forum.doom9.org/showthread.php?t=156191 Quote
outofsync Posted February 23, 2012 Posted February 23, 2012 I had this problem with my ATI 6770. I had to revert to catalyst driver version 11.7 which resolved the picture breakup. I use the microsoft dtv decoder included in win 7 64bit with no problems at all now. Quote
uglyned Posted February 27, 2012 Author Posted February 27, 2012 Thanks again dvbrewer. Interestingly the blockiness came back with the new version but only in DXVA native mode. If I reverted to DXVA copy back mode, it went away. Must be a DXVA thing. Good enough for me! Thanks for the tip. Quote
dvbrewer Posted February 27, 2012 Posted February 27, 2012 O.48 is out, maybe you got it already ? http://forum.doom9.org/showthread.php?t=156191 Quote
