hifi25nl Posted January 24, 2012 Posted January 24, 2012 I am using Tevii 660 usb adapter with the last driver 20111129. Diseq switching from Hotbird 13 to Astra 19.2 is VERY slow and most of time will not be made. In DVBViewer Astra is PosB/optA, Hotbird is PosA/optA The switch was working with Technisat Skystar USB CI. Some suggestions? Quote
QBox User Posted January 24, 2012 Posted January 24, 2012 You could try the Extended DiSEqC command. Insert a delay then repeat the command. What could be happening is that the application is re-sending the command after 5 seconds (default) after the initial failure to tune. This setting can be edited in Channel Edit, on a per channel basis, so you can try it on one channel with a specific delay before changing the setting for the whole satellite. Quote
hifi25nl Posted January 24, 2012 Author Posted January 24, 2012 (edited) I can find extended in DVBViewer but I see only the option of satellite coordinates. In Transedit I see the the delay option, but I don't know how to transfer the diseq setting to DVBViewer without rescanning all channels. P.S. OK, I have found that I must select modify. I will try Edited January 24, 2012 by hifi25nl Quote
hifi25nl Posted January 25, 2012 Author Posted January 25, 2012 I have tried: uncommited 1 delay 100 (or 1000) uncomitted 1 and for the second satellite: uncommited 2 delay 100 (or 1000) uncomitted 2 But the switch is not working. If I resume the computer after a standby the most of time the switch is made... I don't know what to think... Quote
