Palomino3000 Posted January 25, 2012 Posted January 25, 2012 HI, it's possible scheduler a timer and recording with no video playback? Or it's possible scheduler a command with "close video" ? thanx Quote
Tjod Posted January 26, 2012 Posted January 26, 2012 Playback will not be stated for recordings. But is although will not be stopped at a start of a recording. If you use the DVB Task Scheduler make sure "Restart DVBViewer Without Tuning Last Channel" is enabled. Quote
bogdan1980 Posted February 3, 2012 Posted February 3, 2012 or you could use rec service, set an timer from webpage, and videoplayback is not started, rec is done in the background. Quote
