Mike Brown Posted January 28, 2012 Posted January 28, 2012 Hi, Using v4.9.0.0 under Windows XP SP3 (support,zip attached. When I scan for satellite channels several versions of some (radio) channels appear in the channellist though usually only one works, but when I try to select and store in favourites the version which works it seems a different, non-working version of the channel is actually stored in favourites. Typical example is the Classic FM radio channel Very frustrating. Anyone got any clues please? Thanks. Mike Brown Quote
Tjod Posted January 28, 2012 Posted January 28, 2012 Favourites are not fix connected with a channel. They only store some informations about a channel and the first matching channel in the channel list is used. If the difference between the working and the not working channel is not part of the 64-bit ID. You have to remove the not working channel from you channel list (or move it behind the working channel). Bay the way the ID is used for timer as well. So there you will get the same problem. Quote
Mike Brown Posted January 28, 2012 Author Posted January 28, 2012 (edited) Favourites are not fix connected with a channel. They only store some informations about a channel and the first matching channel in the channel list is used. If the difference between the working and the not working channel is not part of the 64-bit ID. You have to remove the not working channel from you channel list (or move it behind the working channel). Bay the way the ID is used for timer as well. So there you will get the same problem. Thanks Tjod. Edited January 28, 2012 by Mike Brown Quote
