Missing EPG in Webinterface?
HomerDK
Hello.
The EPG works fine in DVBViewer.
I can see the interface from other PC, but I can't get the webinterface to show any EPG info or the timers I made directly in DVBViewer.
Did I missed something in DVBViewer or in DVBViewer Recording Service?
Thx
you have to change the time format for the systemaccount in the windows settings. The RS does use, what windows tells him to use...
