DjRaf Posted February 8, 2012 Posted February 8, 2012 Hello, does DVBViewer support LCN, Logical Channel Numbering? This feature allows to automatically assign a unique number to each channel, regardless of frequency or the order in which they are found. Here in Italy LCN has long been in use in DVB-T, but DVBViewer does not seem to care. I am doing something wrong, or the software is not yet able to recognize this information? If so, this function will be integrated in the future? Thanks. Quote
Tjod Posted February 8, 2012 Posted February 8, 2012 does DVBViewer support LCN, Logical Channel Numbering?No >> moved to Suggestions & Ideas Quote
Gioxy Posted February 8, 2012 Posted February 8, 2012 ATM only TransEdit has a first (and limited) support on LCN; you can see LCN values with "Analyze" funcion on a trasponder, looking under "NIT PID / TrasportstreamID / Descriptor = 0x83 = Logical Channel Number"... and that's all, at least until now (...better few than nothing ). Quote
fbi1970 Posted February 25, 2012 Posted February 25, 2012 I do not agree with this policy. LCN is a convenient help in ordering hundreds of channels. DVBViewer should support it. I was looking for a good dvb-t viewer software, but I'll go to ProgDVB which supports it. Thanks Quote
bogdan1980 Posted February 25, 2012 Posted February 25, 2012 go for progdvb, you will be returning after thousands of bugs, lol Quote
fbi1970 Posted February 26, 2012 Posted February 26, 2012 (edited) I'll not return if DVBViewer programmer is so pretentious to think that users are stupid. I want LCN and if DVBViewer programmer does not want to listen to users' need than He does not want me. ProgDVB programmer is available to listen to users. This is the difference. Goodbye, pretentious guys! Edited February 26, 2012 by fbi1970 Quote
QBox User Posted February 27, 2012 Posted February 27, 2012 (edited) As I understand it, LCNs are only unique within networks. For systems with multiple networks, you'd need to have a two-part ID - network (2 digits?) + LCN(3 digits) - so 5-digit numbering. I have used another (single-network) system that maps LCNs to scanned channels and it's a nightmare to configure. Here's a suggested workaround: DVBViewer - How to sort channels by LCN Edited February 27, 2012 by QBox User Quote
fbi1970 Posted February 28, 2012 Posted February 28, 2012 Here's a suggested workaround: DVBViewer - How to sort channels by LCN Your workaround is useless. Here in Italy we have 2-300 channels (over 1000 positions) and the mux contains LCN. Channels are separated in groups in each hundred. In the first hundred you have general channels. In second one you have other channel type. In third one you can found paying channels. In fifth hundred you'll find HD channels. Note: Channels in range 400-499 channels are not used, and so are a lot of channels in each hundred group. Holes between channels are too much. You'll spend hours to "workaround" the LCN, and as soon as you'll rescan channels you'll have to do all the pain again. LCN has been created to avoid this pain. If it exists DVBViewer MUST implement it if it wants to be THE dvb-t software, otherwise it will never be THE one. Bye Quote
QBox User Posted February 28, 2012 Posted February 28, 2012 UK terrestrial doesn't have such gaps, at least not until you reach channels that no-one watches! Radio uses 7xx, but I can never remember them anyway. It might be not so much work to list the stations in LCN order in the Favourites, and to match the numbers that way. Maybe do it in groups of 10 [0-9][10-19]....[200-209]... Can't see LCNs being compatible with multi-networks. Windows MC might be more suitable for you. Quote
fbi1970 Posted February 28, 2012 Posted February 28, 2012 So the matter is that you can have multiple network such as dvb-t and dvb-s cards and there's no way to assign channel numbers? Is this the problem behind the lack of LCN in DVBViewer? Create multiple channel numbers in couples (#card,#channel). Let user choose channels in conventional ways (remote or keyboards). Create a way to switch the gathering data from different dvb cards (2 keys, one up, one down). That's all. Quote
LisaJ Posted May 9, 2014 Posted May 9, 2014 (edited) I've only just bought DVBViewer, so forgive me for asking... Is sorting by LCN still not an option (I'm in UK)? No way am I going to be dragging channels around and filling gaps. It's surprising when things I've taken for granted with other software are not present in DVBViewer. Edited May 9, 2014 by LisaJ Quote
userip Posted June 26, 2016 Posted June 26, 2016 Hi, I'm also interested on this. Will be LCN descriptor supported? Quote
Tjod Posted June 26, 2016 Posted June 26, 2016 The DVBViewer doesn't support to set specific channel numbers or to have gaps in the channel numbering. And that will not change in the foreseeable future. Because it would require huge charges. And as a result of this LCN would only have a very limited benefit. You would only get the channel order but not the numbers from LCN. And only if the are no channel in the channel list before the channel scan. So I don't expect any changes in the near future. Quote
Derrick Posted June 26, 2016 Posted June 26, 2016 It's not the rigid channels.dat structure (concrete is more flexible ) that is to blame why LCNs are not implemented. It's simply the fact that the channel scan procedure doesn't read LCNs from the SI. Otherwise LCNs could be used just like favorites.. Quote
userip Posted June 28, 2016 Posted June 28, 2016 The DVBViewer doesn't support to set specific channel numbers or to have gaps in the channel numbering. And as a result of this LCN would only have a very limited benefit. You would only get the channel order but not the numbers from LCN. And only if the are no channel in the channel list before the channel scan. Hi Tjod, Thank you for explaining. However, please, consider this: * LCN values (on descriptor 0x83) only indicates that the corresponding channel has a "number". * Supporting LCN is "easy" to do with small changes: After the channel scan, and when the full list of channel is completed, then you can only make a full scan of the LCN values of all channels and "automatically" create a new "favourites" list ordered using the LCN numbers. In any case the benefit is HUGE: Instead of the have a chennel list ordered by "operators" (absolutly absurd in DVB-T/T2) you can have a "good ordered list". Remember: for "satellite" the bouquets is the way for "ordered channel lists"; but for DVB-T/T2 the LCN is the correct way. Please, reconsider the support. Quote
userip Posted December 2, 2016 Posted December 2, 2016 Hi, The LCN and LCN-HD descriptors are at time used in all DVB-T2 and some DVB-T networks. Thus, the DVBViewer has a lack of a must have functionality. I hope the developers reconsider the idea to focus only on SATELLITE broadcasts, and considerer TERRESTRIAL (even CABLE) a priority in this good software. Regards. Quote
hackbart Posted December 2, 2016 Posted December 2, 2016 This is not really a lack and not a must have functionality. Why do you really need a LCN for a dozen stations. Sorting them is not that quite hard. Quote
Derrick Posted December 2, 2016 Posted December 2, 2016 This thread started nearly 5 years ago. Since then a lot has changed. To be internationally competitive LCN is a must have Quote
INGBEAN Posted December 8, 2016 Posted December 8, 2016 Hello! It would be very helpful, if DVBViewer supports LCN. An example: my SONY-TV supports it and after a DVB-C scan the channels are sorted automatically. My cable provider (LIWEST in upper austria) broadcasts around 480 TV and Radio stations. After using the LIWEST transponder list for a complete scan, I need a lot of time to sort stations manually... INGBEAN Quote
userip Posted December 9, 2016 Posted December 9, 2016 This is not really a lack and not a must have functionality. Why do you really need a LCN for a dozen stations. Sorting them is not that quite hard. Hi, As I mentioned before: DVBViewer is not only for DVB-S, but for DVB-T2 & DVB-C. I feel the developers of this great software use only satellite broadcasts; and for this reason can say LCN is not a must have... LCN is a REQUIREMENT for hundred of programs found in current DVB-C and DVB-T2 networks. Ordering them manually is a pain, and implementing a simple ordering function (after completing the scanning) using STANDARIZED DESCRIPTORS can't be very complex. So, why not support it? Think on this: all hardware receptors (TVs and STBs) with terrestrial and/or cable tuners support LCN. I hope developers re-think on his position. Quote
userip Posted January 12, 2017 Posted January 12, 2017 Hi, Just a question for developers: No comments? Quote
PeterF Posted January 13, 2017 Posted January 13, 2017 Think on this: all hardware receptors (TVs and STBs) with terrestrial and/or cable tuners support LCN. this is not true...Here and in my family are some TVs and receivers without this and LCN is not logical, it is arbitrary from the contentproviders. Its not so hard to sort once in one or two years some channels. Quote
Derrick Posted January 13, 2017 Posted January 13, 2017 and LCN is not logical, it is arbitrary from the contentproviders. Of course that is the idea behind. Each and and every user wil have an identical channel list. Quote
Derrick Posted January 13, 2017 Posted January 13, 2017 You don't have to use it if you can't see the use of it. (it's not implemented anyway) Why do you think this feature is state of the art in every modern SmartTV? Quote
userip Posted January 13, 2017 Posted January 13, 2017 Hi, I don't like to comment this with people living outside France, Italy, UK, or similar countries using LCNs. Please, STOP to comment that this is absurd... because you don't have it! Remember: Bouquets present in SAT signals are the same as LCN for a terrestrial network. You think that bouquets are absourd? As the descriptor of LCN 0x83 is standarized, and is not complex to implement (simple full scan, and after complete it make a list ordered using the LCN numbers, no more, only present the list ordered by the LCN values in one group), please think on support it. Thank you all that helps to improve this good software. U. 1 Quote
Marco Mognetti Posted April 1, 2018 Posted April 1, 2018 Any news in the implementation of LCN? In many european country we need it. Is a standard! Quote
majstang Posted April 1, 2018 Posted April 1, 2018 Here is a link covering a more technical aspect of the matter. Pay special attention to Grigas 1st post. Considering that l do think their decision to not implement it still stands today. http://www.DVBViewer.tv/forum/topic/46989-extractingusing-lcn-data/?tab=comments#comment-346063 Quote
uglyned Posted April 8, 2018 Posted April 8, 2018 On 02/12/2016 at 8:08 AM, hackbart said: This is not really a lack and not a must have functionality. Why do you really need a LCN for a dozen stations. Sorting them is not that quite hard. This tells the DVBViewer story in one sentence. The developers are unquestionably technically adept but have either no talent or no desire to develop software for the non-technical user. It's technically very clever, but it's not usable from a remote control. You have to be willing to use a mouse / keyboard to get at its features. It misses a lot of functionality that would be expected as standard in a set top box. Quote
userip Posted November 21, 2018 Posted November 21, 2018 Hi, I need to keep asking for the implementation of LCN support. As a customer, this functionality is a must have! I understand that it can have low priority in the TODO list. However, I hope we can see that it's included at some point. Thank you for this good software! Quote
bmpte Posted December 25, 2018 Posted December 25, 2018 Huh, we have 2018 year, we have 16-year old program, and no LCN for DVB-C/T ... Oh wait... there are no Network Scan too (0x62 in NIT - frequency list description) ... Rly? ;) 1 Quote
