Nayef Posted February 10, 2012 Posted February 10, 2012 Hi I have freeze system very slow & lag when recorder start service . And go slow when recording stops (Some time) after force restart PC , Card DVB-S not found ... After OFF\ON PC working fine My system : 1- Windows 7 32b 2- Card : TBS6984 DVB-S2 Quad Tuner PCIe Card 3- DVBViewer 4.9 4- RS 1.9.3.0 I do not know the cause of the problem you are RS 1.9.3.0 or DVBViewer 4.9 or windows7 ??? Card working fine on windows XP SP3 any help ? support.zip
QBox User Posted February 10, 2012 Posted February 10, 2012 You have potential card conflicts with 3 applications - DVBViewer Pro, Recording Service and Windows Media Center. You should disable Media Center service, and disable the tuners in DVBViewer Pro (Options-Hardware), adding 4 Unicast satellite devices instead.
Nayef Posted February 11, 2012 Author Posted February 11, 2012 You have potential card conflicts with 3 applications - DVBViewer Pro, Recording Service and Windows Media Center. You should disable Media Center service, and disable the tuners in DVBViewer Pro (Options-Hardware), adding 4 Unicast satellite devices instead. thanks . i well try that how adding 4 Unicast satellite devices ?
Tjod Posted February 11, 2012 Posted February 11, 2012 http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide
Nayef Posted February 11, 2012 Author Posted February 11, 2012 http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide thanks pro i do that, now system ok && need more for test ... also i apply hot fix from Microsoft (Windows6.1-KB2575077-x86.msu) More info : http://support.microsoft.com/kb/2575077
Nayef Posted February 23, 2012 Author Posted February 23, 2012 after more work to week ... freeze return again any idea !
Gugaoforums Posted March 11, 2012 Posted March 11, 2012 hello nayef!! I have the same card! and I'm in the same situation!! I dont know more what to do? I dont know if the problem is the software or hardware??? come learn togheter to solve our problem? I pm my mail to you ok
