audio PID identification in TS-Analyzer (TransEDit)
fundom
When I use TS-Analyzer inside TransEdit for recording of selected A/V streams, many channels have more than one audio PIDS with different languages. However, TS-Analyzer does not show any info about which PID carry which language track. It would be useful addition to this application if PID also have respective language info. Thanks & regards.
..read the manual. Then you'll know where to look for the language descriptor :bye:
The PMT basically lists all Elementary Streams (ES), that belong to a service resp. channel, and their corresponding PIDs. The list is usually seasoned with some Descriptors. That are sub-structures within SI tables, specifying properties of services, streams etc. in detail, for example the language of an audio stream, or the teletext initial page.
Thank you Derrick! But I was wishing for this kind of info inside the "Stream Type" column.
