Streaming problem
alve
Hello,
I have problem getting streaming to work. I go on the webbpage pic a canal start streaming getting the play icon and then it just says "loading..." for ever. I looked in the logg file svcdebug and getting this.
Any one knowing what the problem is? Somthing look not OK at "Converter Start cmd -threads 2 -er 4 -i"
The problem is the same on all devices Windows, iPhone, iPad.
18.02.12 22:33:31.001 AddReference     webserver: 1
18.02.12 22:34:00.195 client doflashstream Preset=3&aspect=16%3A9&ffPreset=normal&maxwidth=&maxheight=&chid=0
18.02.12 22:34:00.199 Converter Start cmd -threads 2 -er 4   -i "http://127.0.0.1:7522/upnp/channelstream/oneaudio/0.ts" -threads 2 -f flv -vcodec libx264 -bufsize 1024k -b:v 1200k -bt 1300k -r 25.0 -map 0:0 -map 0:1 -vf "yadif=0:-1:1, scale=min(800\, trunc(iw/2)*2):trunc((ow/dar)/2)*2" -vpre normal -vprofile baseline -level 30 -acodec libmp3lame -ab 192k -ar 44100 -ac 2 -async 1 -y "\\.\pipe\Output{6EFA6BB0-A203-4669-9977-9D7705158614}"
18.02.12 22:34:00.488 FFMPEG           ffmpeg version N-37915-g6cb2085 Copyright (c) 2000-2012 the FFmpeg developers
18.02.12 22:34:00.488 FFMPEG             built on Feb 15 2012 20:47:20 with gcc 4.6.2
18.02.12 22:34:00.488 FFMPEG             configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
18.02.12 22:34:00.488 FFMPEG             libavutil      51. 39.100 / 51. 39.100
18.02.12 22:34:00.488 FFMPEG             libavcodec     54.  3.100 / 54.  3.100
18.02.12 22:34:00.488 FFMPEG             libavformat    54.  1.100 / 54.  1.100
18.02.12 22:34:00.488 FFMPEG             libavdevice    53.  4.100 / 53.  4.100
18.02.12 22:34:00.488 FFMPEG             libavfilter     2. 62.100 /  2. 62.100
18.02.12 22:34:00.488 FFMPEG             libswscale      2.  1.100 /  2.  1.100
18.02.12 22:34:00.488 FFMPEG             libswresample   0.  6.100 /  0.  6.100
18.02.12 22:34:00.488 FFMPEG             libpostproc    52.  0.100 / 52.  0.100
18.02.12 22:34:00.488 FFMPEG           Unrecognized option 'er'
18.02.12 22:34:00.488 FFMPEG           Failed to set value '4' for option 'er'
Thanx now it's working!!! But a lot of errors looking in the log after 1 min streaming lokking like this. And my CPU is quite lot loaded.
Do i need to change anything more??
Martin
19.02.12 10:08:47.366 AddReference     webserver: 1
19.02.12 10:08:47.832 AddReference     TStreamClient: 2
19.02.12 10:08:47.986 TBDAFireDTV.Opendevice bvUnknown
19.02.12 10:08:48.088 tStreamClient Allocate FireDTV BDA Tuner DVBS2
19.02.12 10:08:48.636 TBDACIFireDTVModule CI Base SetTuner Entering
19.02.12 10:08:49.255 TBDACIFireDTVModule CI Base SetTuner Leaving
19.02.12 10:08:49.256 TDVBHardware.SetTuner Set Plugins
19.02.12 10:08:49.256 TDVBHardware.SetTuner Set Plugins done
19.02.12 10:08:49.364  Allocate        FireDTV BDA Tuner DVBS2
19.02.12 10:08:49.504 TBDACIFireDTVModule WinProc Received PMT ready
19.02.12 10:08:50.591 TBDACIFireDTVModule.InitModule Available
19.02.12 10:08:52.933  Release         FireDTV BDA Tuner DVBS2
19.02.12 10:08:57.138 FFMPEG           ffmpeg version N-36890-g67f5650 Copyright (c) 2000-2012 the FFmpeg developers
19.02.12 10:08:57.138 FFMPEG             built on Jan 16 2012 21:57:13 with gcc 4.6.2
19.02.12 10:08:57.138 FFMPEG             configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
19.02.12 10:08:57.138 FFMPEG             libavutil      51. 34.100 / 51. 34.100
19.02.12 10:08:57.138 FFMPEG             libavcodec     53. 56.105 / 53. 56.105
19.02.12 10:08:57.138 FFMPEG             libavformat    53. 30.100 / 53. 30.100
19.02.12 10:08:57.138 FFMPEG             libavdevice    53.  4.100 / 53.  4.100
19.02.12 10:08:57.138 FFMPEG             libavfilter     2. 59.100 /  2. 59.100
19.02.12 10:08:57.138 FFMPEG             libswscale      2.  1.100 /  2.  1.100
19.02.12 10:08:57.138 FFMPEG             libswresample   0.  6.100 /  0.  6.100
19.02.12 10:08:57.138 FFMPEG             libpostproc    51.  2.100 / 51.  2.100
19.02.12 10:08:57.138 FFMPEG           [mp3 @ 02691EE0] Header missing
19.02.12 10:08:57.138 FFMPEG           [mpegts @ 0209D2A0] max_analyze_duration 5000000 reached at 5016000
19.02.12 10:08:57.138 FFMPEG           [mpegts @ 0209D2A0] Estimating duration from bitrate, this may be inaccurate
19.02.12 10:08:57.138 FFMPEG           Input #0, mpegts, from 'http://192.168.1.2:7522/upnp/channelstream/3.ts':
19.02.12 10:08:57.138 FFMPEG             Duration: N/A, start: 75026.955922, bitrate: 10256 kb/s
19.02.12 10:08:57.138 FFMPEG             Program 1602
19.02.12 10:08:57.138 FFMPEG               Stream #0:0[0x200]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 720x576 [sAR 64:45 DAR 16:9], 10000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
19.02.12 10:08:57.138 FFMPEG               Stream #0:1[0x280](swe): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16, 256 kb/s
19.02.12 10:08:57.138 FFMPEG               Stream #0:2[0x240](swe): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
19.02.12 10:08:57.138 FFMPEG           [buffer @ 026C3760] w:720 h:576 pixfmt:yuv420p tb:1/1000000 sar:64/45 sws_param:
19.02.12 10:08:57.138 FFMPEG           [yadif @ 03FF8A60] mode:0 parity:-1 auto_enable:1
19.02.12 10:08:57.138 FFMPEG           [scale @ 0272E5E0] w:720 h:576 fmt:yuv420p -> w:720 h:404 fmt:yuv420p flags:0x4
19.02.12 10:08:57.138 FFMPEG           [libx264 @ 03FF8640] VBV maxrate unspecified, assuming CBR
19.02.12 10:08:57.138 FFMPEG           [libx264 @ 03FF8640] using SAR=404/405
19.02.12 10:08:57.138 FFMPEG           [libx264 @ 03FF8640] using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
19.02.12 10:08:57.138 FFMPEG           [libx264 @ 03FF8640] profile Constrained Baseline, level 3.0
19.02.12 10:08:57.138 FFMPEG           [mpegts @ 03FFF900] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
19.02.12 10:08:57.138 FFMPEG           Output #0, mpegts, to '\\.\pipe\Output{A806328C-84FD-484A-B9CA-46E9AB988BDB}':
19.02.12 10:08:57.138 FFMPEG             Metadata:
19.02.12 10:08:57.138 FFMPEG               encoder         : Lavf53.30.100
19.02.12 10:08:57.138 FFMPEG               Stream #0:0: Video: h264, yuv420p, 720x404 [sAR 404:405 DAR 16:9], q=10-51, 680 kb/s, 90k tbn, 25 tbc
19.02.12 10:08:57.138 FFMPEG               Stream #0:1(swe): Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
19.02.12 10:08:57.138 FFMPEG           Stream mapping:
19.02.12 10:08:57.138 FFMPEG             Stream #0:0 -> #0:0 (mpeg2video -> libx264)
19.02.12 10:08:57.138 FFMPEG             Stream #0:1 -> #0:1 (mp2 -> libmp3lame)
19.02.12 10:08:57.138 FFMPEG           Press [q] to stop, [?] for help
19.02.12 10:08:57.138 FFMPEG           [mp2 @ 02691EE0] Header missing
19.02.12 10:08:57.138 FFMPEG           Error while decoding stream #0:1
19.02.12 10:08:57.138 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:08:57.138 FFMPEG           [mpeg2video @ 0209FA20] Warning MVs not available
19.02.12 10:08:57.138 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:08:57.138 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:08:57.138 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:08:57.138 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=84 0
19.02.12 10:08:57.139 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:08:57.139 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:08:57.139 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:08:57.468 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:08:57.468 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:08:57.468 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:08:57.468 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:08:57.468 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=332 0
19.02.12 10:08:57.468 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=924 0
19.02.12 10:08:57.468 FFMPEG           frame=    6 fps=  0 q=36.0 size=       0kB time=00:00:00.20 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:08:57.978 FFMPEG           end mismatch left=20 0
19.02.12 10:08:57.978 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:08:57.978 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:08:57.978 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:08:57.978 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:08:57.978 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=940 0
19.02.12 10:08:57.978 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=932 0
19.02.12 10:08:57.978 FFMPEG           frame=   33 fps= 33 q=32.0 size=       0kB time=00:00:01.28 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:08:58.497 FFMPEG           end mismatch left=28 0
19.02.12 10:08:58.497 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:08:58.497 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:08:58.497 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:08:58.497 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=100 0
19.02.12 10:08:58.497 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:08:58.497 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=140 0
19.02.12 10:08:58.497 FFMPEG           frame=   58 fps= 38 q=30.0 size=       0kB time=00:00:02.28 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:08:58.997 FFMPEG           end mismatch left=28 0
19.02.12 10:08:58.997 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:08:58.997 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:08:58.997 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:08:58.997 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=420 0
19.02.12 10:08:58.997 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:08:58.997 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=716 0
19.02.12 10:08:58.997 FFMPEG           frame=   83 fps= 41 q=30.0 size=       0kB time=00:00:03.28 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:08:59.503 FFMPEG           end mismatch left=28 0
19.02.12 10:08:59.503 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:08:59.503 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:08:59.503 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1404 0
19.02.12 10:08:59.503 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:08:59.503 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:08:59.503 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:08:59.503 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=292 0
19.02.12 10:08:59.503 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:08:59.503 FFMPEG           frame=  109 fps= 43 q=26.0 size=       0kB time=00:00:04.32 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:00.031 FFMPEG           end mismatch left=2964 0
19.02.12 10:09:00.031 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:00.031 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=26 0
19.02.12 10:09:00.031 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:00.031 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:00.031 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:00.031 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=324 0
19.02.12 10:09:00.031 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=956 0
19.02.12 10:09:00.031 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:00.031 FFMPEG           frame=  138 fps= 45 q=20.0 size=       0kB time=00:00:05.48 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:00.402 Split            3011
19.02.12 10:09:00.527 FFMPEG           end mismatch left=28 0
19.02.12 10:09:00.527 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:00.527 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:00.527 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:00.527 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:00.527 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=860 0
19.02.12 10:09:00.527 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=26 0
19.02.12 10:09:00.527 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=628 0
19.02.12 10:09:00.527 FFMPEG           frame=  167 fps= 47 q=19.0 size=       0kB time=00:00:06.64 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:01.020 FFMPEG           end mismatch left=20 0
19.02.12 10:09:01.020 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:01.020 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:01.020 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=804 0
19.02.12 10:09:01.020 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:01.020 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:01.020 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:01.020 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=156 0
19.02.12 10:09:01.020 FFMPEG           frame=  188 fps= 46 q=19.0 size=       0kB time=00:00:07.48 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:01.540 FFMPEG           end mismatch left=20 0
19.02.12 10:09:01.540 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:01.540 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:01.540 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:01.540 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1012 0
19.02.12 10:09:01.540 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:01.540 FFMPEG           frame=  200 fps= 44 q=19.0 size=       0kB time=00:00:07.96 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:02.039 FFMPEG           end mismatch left=20 0
19.02.12 10:09:02.039 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:02.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:02.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:02.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1372 0
19.02.12 10:09:02.039 FFMPEG           frame=  211 fps= 41 q=21.0 size=       0kB time=00:00:08.40 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:02.548 FFMPEG           end mismatch left=12 0
19.02.12 10:09:02.548 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:02.548 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:02.548 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:02.548 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:02.548 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=268 0
19.02.12 10:09:02.548 FFMPEG           frame=  224 fps= 40 q=29.0 size=       0kB time=00:00:08.92 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:03.047 FFMPEG           end mismatch left=12 0
19.02.12 10:09:03.047 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:03.047 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:03.047 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:03.047 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=556 0
19.02.12 10:09:03.047 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:03.047 FFMPEG           frame=  235 fps= 39 q=30.0 size=       0kB time=00:00:09.36 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:03.514 Split            3120
19.02.12 10:09:03.558 FFMPEG           end mismatch left=28 0
19.02.12 10:09:03.558 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:03.558 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:03.558 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:03.558 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=356 0
19.02.12 10:09:03.558 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:03.558 FFMPEG           frame=  249 fps= 38 q=31.0 size=       0kB time=00:00:09.92 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:04.095 FFMPEG           end mismatch left=28 0
19.02.12 10:09:04.095 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:04.095 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:04.095 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:04.095 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1276 0
19.02.12 10:09:04.095 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:04.095 FFMPEG           frame=  262 fps= 37 q=30.0 size=       0kB time=00:00:10.44 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:04.572 FFMPEG           end mismatch left=12 0
19.02.12 10:09:04.572 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:04.572 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:04.572 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1252 0
19.02.12 10:09:04.572 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:04.572 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:04.572 FFMPEG           frame=  275 fps= 36 q=30.0 size=       0kB time=00:00:10.96 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:05.102 FFMPEG           end mismatch left=12 0
19.02.12 10:09:05.102 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:05.102 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=308 0
19.02.12 10:09:05.102 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:05.102 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:05.102 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:05.102 FFMPEG           frame=  289 fps= 36 q=30.0 size=       0kB time=00:00:11.52 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:05.609 FFMPEG           end mismatch left=1212 0
19.02.12 10:09:05.609 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:05.609 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:05.609 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:05.609 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:05.609 FFMPEG           frame=  301 fps= 35 q=30.0 size=       0kB time=00:00:12.00 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:06.110 FFMPEG           end mismatch left=564 0
19.02.12 10:09:06.110 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:06.110 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:06.110 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:06.110 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:06.110 FFMPEG           frame=  313 fps= 34 q=30.0 size=       0kB time=00:00:12.48 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:06.610 FFMPEG           end mismatch left=764 0
19.02.12 10:09:06.610 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:06.610 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:06.610 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:06.610 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:06.610 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:06.610 FFMPEG           frame=  325 fps= 34 q=30.0 size=       0kB time=00:00:12.96 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:06.651 Split            3135
19.02.12 10:09:07.119 FFMPEG           end mismatch left=220 0
19.02.12 10:09:07.119 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:07.119 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:07.119 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:07.119 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:07.119 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1004 0
19.02.12 10:09:07.119 FFMPEG           frame=  338 fps= 33 q=30.0 size=       0kB time=00:00:13.48 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:07.626 FFMPEG           end mismatch left=26 0
19.02.12 10:09:07.626 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:07.626 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:07.626 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:07.626 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:07.626 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=732 0
19.02.12 10:09:07.626 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:07.626 FFMPEG           frame=  352 fps= 33 q=30.0 size=       0kB time=00:00:14.04 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:08.160 FFMPEG           end mismatch left=12 0
19.02.12 10:09:08.160 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:08.160 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:08.160 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:08.160 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=452 0
19.02.12 10:09:08.160 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=26 0
19.02.12 10:09:08.160 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:08.160 FFMPEG           frame=  366 fps= 33 q=32.0 size=       0kB time=00:00:14.60 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:08.646 FFMPEG           end mismatch left=20 0
19.02.12 10:09:08.646 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:08.646 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:08.646 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:08.646 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:08.646 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=3668 0
19.02.12 10:09:08.646 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=26 0
19.02.12 10:09:08.646 FFMPEG           frame=  379 fps= 32 q=29.0 size=       0kB time=00:00:15.12 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:09.174 FFMPEG           end mismatch left=20 0
19.02.12 10:09:09.174 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:09.174 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:09.174 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:09.174 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=316 0
19.02.12 10:09:09.174 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=26 0
19.02.12 10:09:09.174 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:09.174 FFMPEG           frame=  390 fps= 32 q=29.0 size=       0kB time=00:00:15.56 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:09.656 Split            3011
19.02.12 10:09:09.664 FFMPEG           end mismatch left=12 0
19.02.12 10:09:09.664 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:09.664 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:09.664 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:09.664 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=156 0
19.02.12 10:09:09.664 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:09.664 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:09.664 FFMPEG           frame=  406 fps= 32 q=27.0 size=       0kB time=00:00:16.20 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:10.187 FFMPEG           end mismatch left=28 0
19.02.12 10:09:10.187 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:10.187 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:10.187 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:10.187 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1380 0
19.02.12 10:09:10.187 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:10.187 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:10.188 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:10.188 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:10.188 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:10.188 FFMPEG           frame=  418 fps= 32 q=25.0 size=       0kB time=00:00:16.68 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:10.681 FFMPEG           end mismatch left=12 0
19.02.12 10:09:10.681 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:10.681 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1116 0
19.02.12 10:09:10.681 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:10.681 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:10.681 FFMPEG           frame=  433 fps= 32 q=28.0 size=       0kB time=00:00:17.28 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:11.197 FFMPEG           end mismatch left=484 0
19.02.12 10:09:11.197 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:11.197 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:11.197 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:11.197 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:11.197 FFMPEG           frame=  445 fps= 31 q=28.0 size=       0kB time=00:00:17.76 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:11.713 FFMPEG           end mismatch left=1092 0
19.02.12 10:09:11.713 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:11.713 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=26 0
19.02.12 10:09:11.713 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:11.713 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:11.713 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:11.713 FFMPEG           frame=  457 fps= 31 q=28.0 size=       0kB time=00:00:18.24 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:12.217 FFMPEG           end mismatch left=284 0
19.02.12 10:09:12.217 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:12.217 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:12.217 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:12.217 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:12.217 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:12.217 FFMPEG           frame=  469 fps= 31 q=25.0 size=       0kB time=00:00:18.72 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:12.720 FFMPEG           end mismatch left=1348 0
19.02.12 10:09:12.720 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:12.720 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:12.720 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:12.720 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:12.720 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:12.720 FFMPEG           frame=  481 fps= 31 q=24.0 size=       0kB time=00:00:19.20 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:12.859 Split            3198
19.02.12 10:09:13.284 FFMPEG           end mismatch left=1140 0
19.02.12 10:09:13.284 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:13.284 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:13.284 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:13.284 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:13.284 FFMPEG           frame=  493 fps= 30 q=23.0 size=       0kB time=00:00:19.68 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:13.785 FFMPEG           end mismatch left=1140 0
19.02.12 10:09:13.785 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:13.785 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:13.785 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:13.785 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:13.785 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:13.785 FFMPEG           frame=  505 fps= 30 q=24.0 size=       0kB time=00:00:20.16 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:14.252 FFMPEG           end mismatch left=924 0
19.02.12 10:09:14.252 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:14.252 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:14.252 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:14.252 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:14.252 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:14.252 FFMPEG           frame=  517 fps= 30 q=24.0 size=       0kB time=00:00:20.64 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:14.753 FFMPEG           end mismatch left=60 0
19.02.12 10:09:14.753 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:14.753 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:14.753 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:14.753 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:14.753 FFMPEG           frame=  529 fps= 30 q=24.0 size=       0kB time=00:00:21.12 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:15.254 FFMPEG           end mismatch left=18 0
19.02.12 10:09:15.254 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:15.254 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:15.254 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:15.254 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:15.254 FFMPEG           frame=  541 fps= 30 q=23.0 size=       0kB time=00:00:21.60 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:15.788 FFMPEG           end mismatch left=892 0
19.02.12 10:09:15.788 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:15.788 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:15.788 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:15.788 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:15.788 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:15.788 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:15.788 FFMPEG           frame=  553 fps= 29 q=24.0 size=       0kB time=00:00:22.08 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:16.264 FFMPEG           end mismatch left=1436 0
19.02.12 10:09:16.264 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:16.264 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:16.264 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:16.264 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=340 0
19.02.12 10:09:16.264 FFMPEG           frame=  566 fps= 29 q=24.0 size=       0kB time=00:00:22.60 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:16.767 FFMPEG           end mismatch left=12 0
19.02.12 10:09:16.767 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:16.767 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:16.767 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:16.767 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:16.767 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:16.767 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=184 0
19.02.12 10:09:16.767 FFMPEG           frame=  580 fps= 29 q=24.0 size=       0kB time=00:00:23.16 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:17.268 FFMPEG           end mismatch left=16 0
19.02.12 10:09:17.269 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:17.269 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:17.269 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:17.269 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=136 0
19.02.12 10:09:17.269 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:17.269 FFMPEG           frame=  592 fps= 29 q=24.0 size=       0kB time=00:00:23.64 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:17.776 FFMPEG           end mismatch left=16 0
19.02.12 10:09:17.776 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:17.776 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:17.776 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:17.776 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=320 0
19.02.12 10:09:17.776 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=31 0
19.02.12 10:09:17.776 FFMPEG           frame=  606 fps= 29 q=29.0 size=       0kB time=00:00:24.20 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:17.931 Split            5070
19.02.12 10:09:18.267 FFMPEG           end mismatch left=24 0
19.02.12 10:09:18.267 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:18.267 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:18.267 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:18.267 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=912 0
19.02.12 10:09:18.267 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=31 0
19.02.12 10:09:18.267 FFMPEG           frame=  619 fps= 29 q=29.0 size=       0kB time=00:00:24.72 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:18.768 FFMPEG           end mismatch left=24 0
19.02.12 10:09:18.768 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:18.768 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:18.768 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=240 0
19.02.12 10:09:18.768 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:18.768 FFMPEG           frame=  631 fps= 29 q=29.0 size=       0kB time=00:00:25.20 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:19.292 FFMPEG           end mismatch left=24 0
19.02.12 10:09:19.292 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:19.292 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:19.292 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1080 0
19.02.12 10:09:19.292 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=31 0
19.02.12 10:09:19.292 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:19.292 FFMPEG           frame=  643 fps= 29 q=27.0 size=       0kB time=00:00:25.68 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:19.826 FFMPEG           end mismatch left=16 0
19.02.12 10:09:19.826 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:19.826 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:19.826 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:19.826 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1368 0
19.02.12 10:09:19.826 FFMPEG           frame=  654 fps= 29 q=31.0 size=       0kB time=00:00:26.12 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:20.293 FFMPEG           end mismatch left=16 0
19.02.12 10:09:20.293 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:20.293 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:20.293 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:20.293 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1376 0
19.02.12 10:09:20.293 FFMPEG           frame=  667 fps= 29 q=30.0 size=       0kB time=00:00:26.64 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:20.816 FFMPEG           end mismatch left=16 0
19.02.12 10:09:20.816 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:20.816 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:20.816 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:20.816 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=944 0
19.02.12 10:09:20.816 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=8664 0
19.02.12 10:09:20.816 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=4376 0
19.02.12 10:09:20.816 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:20.816 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=248 0
19.02.12 10:09:20.816 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=31 0
19.02.12 10:09:20.816 FFMPEG           frame=  688 fps= 29 q=29.0 size=       0kB time=00:00:27.48 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:21.329 FFMPEG           end mismatch left=2344 0
19.02.12 10:09:21.329 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:21.329 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:21.329 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=3320 0
19.02.12 10:09:21.329 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=4472 0
19.02.12 10:09:21.329 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=21 0
19.02.12 10:09:21.329 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:21.329 FFMPEG           frame=  704 fps= 29 q=29.0 size=       0kB time=00:00:28.12 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:21.828 FFMPEG           end mismatch left=12 0
19.02.12 10:09:21.828 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:21.828 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:21.828 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1400 0
19.02.12 10:09:21.828 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:21.828 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:21.828 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:21.828 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:21.828 FFMPEG           frame=  721 fps= 29 q=23.0 size=       0kB time=00:00:28.80 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:22.386 FFMPEG           end mismatch left=1260 0
19.02.12 10:09:22.386 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:22.386 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=13 0
19.02.12 10:09:22.386 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:22.386 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1280 0
19.02.12 10:09:22.386 FFMPEG           frame=  735 fps= 29 q=17.0 size=       0kB time=00:00:29.36 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:22.930 FFMPEG           end mismatch left=16 0
19.02.12 10:09:22.930 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:22.930 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:22.930 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:22.930 FFMPEG           frame=  745 fps= 29 q=15.0 size=       0kB time=00:00:29.76 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:23.038 Split            5101
19.02.12 10:09:23.430 FFMPEG           end mismatch left=1432 0
19.02.12 10:09:23.430 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:23.430 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:23.430 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:23.430 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=21 0
19.02.12 10:09:23.430 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:23.430 FFMPEG           frame=  757 fps= 29 q=12.0 size=       0kB time=00:00:30.24 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:23.964 FFMPEG           frame=  757 fps= 28 q=12.0 size=       0kB time=00:00:30.24 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:24.483 FFMPEG           end mismatch left=903 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=19 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=26 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=11 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=399 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=25 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:24.483 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:24.483 FFMPEG           frame=  775 fps= 28 q=14.0 size=       0kB time=00:00:30.96 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:24.999 FFMPEG           end mismatch left=10 0
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=21 0
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=566 0
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=31 0
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:24.999 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=23 0
19.02.12 10:09:24.999 FFMPEG           frame=  788 fps= 28 q=11.0 size=       0kB time=00:00:31.48 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:25.499 FFMPEG           end mismatch left=25 0
19.02.12 10:09:25.499 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:25.499 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=17 0
19.02.12 10:09:25.499 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=462 0
19.02.12 10:09:25.499 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=19 0
19.02.12 10:09:25.499 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:25.499 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=21 0
19.02.12 10:09:25.499 FFMPEG           frame=  799 fps= 28 q=10.0 size=       0kB time=00:00:31.92 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:26.000 FFMPEG           end mismatch left=12 0
19.02.12 10:09:26.000 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:26.000 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=11 0
19.02.12 10:09:26.000 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:26.000 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=25 0
19.02.12 10:09:26.000 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1301 0
19.02.12 10:09:26.000 FFMPEG           frame=  810 fps= 28 q=25.0 size=       0kB time=00:00:32.36 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:26.509 FFMPEG           end mismatch left=29 0
19.02.12 10:09:26.509 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:26.509 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=23 0
19.02.12 10:09:26.509 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=21 0
19.02.12 10:09:26.509 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:26.509 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:26.509 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:26.509 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:26.509 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:26.509 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:26.509 FFMPEG           frame=  824 fps= 28 q=28.0 size=       0kB time=00:00:32.92 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:27.039 FFMPEG           end mismatch left=13 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=19 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=22 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=29 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=329 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=21 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:27.039 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:27.039 FFMPEG           frame=  839 fps= 28 q=28.0 size=       0kB time=00:00:33.52 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:27.579 FFMPEG           end mismatch left=10 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=29 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1295 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=27 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=25 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=13 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:27.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:27.580 FFMPEG           frame=  853 fps= 28 q=29.0 size=       0kB time=00:00:34.08 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:28.039 Split            5008
19.02.12 10:09:28.074 FFMPEG           end mismatch left=488 0
19.02.12 10:09:28.074 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:28.074 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=27 0
19.02.12 10:09:28.074 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:28.074 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:28.074 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=23 0
19.02.12 10:09:28.074 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=21 0
19.02.12 10:09:28.074 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:28.074 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=30 0
19.02.12 10:09:28.074 FFMPEG           frame=  864 fps= 28 q=32.0 size=       0kB time=00:00:34.52 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:28.574 FFMPEG           end mismatch left=1388 0
19.02.12 10:09:28.574 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:28.574 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:28.574 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=11 0
19.02.12 10:09:28.574 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=17 0
19.02.12 10:09:28.574 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:28.574 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=31 0
19.02.12 10:09:28.574 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=19 0
19.02.12 10:09:28.574 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=23 0
19.02.12 10:09:28.574 FFMPEG           frame=  877 fps= 28 q=30.0 size=       0kB time=00:00:35.04 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:29.057 FFMPEG           end mismatch left=395 0
19.02.12 10:09:29.057 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:29.057 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:29.057 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=26 0
19.02.12 10:09:29.057 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:29.057 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:29.057 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=27 0
19.02.12 10:09:29.057 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=21 0
19.02.12 10:09:29.057 FFMPEG           frame=  889 fps= 28 q=31.0 size=       0kB time=00:00:35.52 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:29.580 FFMPEG           end mismatch left=789 0
19.02.12 10:09:29.580 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:29.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:29.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=11 0
19.02.12 10:09:29.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=13 0
19.02.12 10:09:29.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:29.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:29.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=29 0
19.02.12 10:09:29.580 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=22 0
19.02.12 10:09:29.580 FFMPEG           frame=  901 fps= 28 q=31.0 size=       0kB time=00:00:36.00 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:30.194 FFMPEG           end mismatch left=542 0
19.02.12 10:09:30.194 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:30.194 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=13 0
19.02.12 10:09:30.194 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:30.194 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:30.194 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=31 0
19.02.12 10:09:30.194 FFMPEG           frame=  910 fps= 27 q=33.0 size=       0kB time=00:00:36.36 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:30.685 FFMPEG           end mismatch left=24 0
19.02.12 10:09:30.685 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:30.685 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=499 0
19.02.12 10:09:30.685 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:30.685 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:30.685 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:30.685 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=23 0
19.02.12 10:09:30.685 FFMPEG           frame=  922 fps= 27 q=30.0 size=       0kB time=00:00:36.84 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:31.263 FFMPEG           end mismatch left=30 0
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=17 0
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=51 0
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=19 0
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=30 0
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=29 0
19.02.12 10:09:31.263 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:31.263 FFMPEG           frame=  937 fps= 27 q=28.0 size=       0kB time=00:00:37.44 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:31.737 FFMPEG           end mismatch left=480 0
19.02.12 10:09:31.737 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:31.737 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=30 0
19.02.12 10:09:31.737 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:31.737 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:31.737 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:31.737 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:31.737 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:31.738 FFMPEG           frame=  949 fps= 27 q=27.0 size=       0kB time=00:00:37.92 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:32.258 FFMPEG           end mismatch left=789 0
19.02.12 10:09:32.258 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:32.258 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=23 0
19.02.12 10:09:32.258 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:32.258 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=13 0
19.02.12 10:09:32.258 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=21 0
19.02.12 10:09:32.258 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:32.258 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:32.258 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=983 0
19.02.12 10:09:32.258 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:32.258 FFMPEG           frame=  964 fps= 27 q=25.0 size=       0kB time=00:00:38.52 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:32.730 FFMPEG           end mismatch left=11 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=27 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=24 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=18 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=28 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=11 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=20 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1226 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=22 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=19 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=13 0
19.02.12 10:09:32.730 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=31 0
19.02.12 10:09:32.730 FFMPEG           frame=  982 fps= 27 q=28.0 size=       0kB time=00:00:39.24 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:33.055 Split            5023
19.02.12 10:09:33.262 FFMPEG           end mismatch left=20 0
19.02.12 10:09:33.262 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:33.262 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=22 0
19.02.12 10:09:33.262 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:33.262 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=368 0
19.02.12 10:09:33.262 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=12 0
19.02.12 10:09:33.262 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:33.262 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=23 0
19.02.12 10:09:33.262 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=29 0
19.02.12 10:09:33.262 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=25 0
19.02.12 10:09:33.262 FFMPEG           frame=  996 fps= 27 q=27.0 size=       0kB time=00:00:39.80 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:33.792 FFMPEG           end mismatch left=18 0
19.02.12 10:09:33.792 FFMPEG           [mpeg2video @ 0209FA20] concealing 45 DC, 45 AC, 45 MV errors
19.02.12 10:09:33.792 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=1308 0
19.02.12 10:09:33.792 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=15 0
19.02.12 10:09:33.792 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=16 0
19.02.12 10:09:33.792 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=14 0
19.02.12 10:09:33.792 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=10 0
19.02.12 10:09:33.792 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=19 0
19.02.12 10:09:33.792 FFMPEG           [mpeg2video @ 0209FA20] end mismatch left=9 0
19.02.12 10:09:33.792 FFMPEG           frame= 1009 fps= 27 q=27.0 size=       0kB time=00:00:40.32 bitrate=   0.0kbits/s dup=13 drop=0
19.02.12 10:09:34.218 tStreamClient Release FireDTV BDA Tuner DVBS2
19.02.12 10:09:34.218 tStreamClient Destroy FireDTV BDA Tuner DVBS2
19.02.12 10:09:34.337 tStreamClient Destroyed FireDTV BDA Tuner DVBS2
19.02.12 10:09:34.337 tStreamClient hamDeleted FireDTV BDA Tuner DVBS2
19.02.12 10:09:34.337 Releasereference TStreamClient: 1
