khater Posted September 24, 2004 Posted September 24, 2004 i have connected the cable from Eutelsat W3 i have tried the connection into a normal Digital Reciever and it works fine with SkyStar2 i couldn't recieve any signal, when i install the cards it detects the network card of SS2. i have tried it in several PC's with same issue . i got this messages one after the other. first one: can't Set Tunerstauts (wrong settings), error 0×90010115 second one: EAccessViolation raisd by instance tvChannels of class T Treeview at 05747241 please help me Quote
Gioxy Posted September 24, 2004 Posted September 24, 2004 (edited) Hi khater, before ask something you have to inform as about your installation a little more; so, please, read at least the six row How to submit a bug report : on top of this page... ...just to try to guess: what kind and version of driver have you installed for your SS2 card? Gioxy Edited September 24, 2004 by Gioxy Quote
khater Posted September 24, 2004 Author Posted September 24, 2004 For the B2C2 Broadband Reciever PCI Adapter (Network card) Driver virsion 4.2.10.9999 . i got it from device manager. i attatch the two files log file, ini file and other txt file. MPEGDecoder.txt Quote
khater Posted September 24, 2004 Author Posted September 24, 2004 this is a log file DVBViewer.log Quote
Klausing Posted September 25, 2004 Posted September 25, 2004 Had you made a channelscan? And what kind of system have you? SkyDVB Video DecoderWhat kind of Decoder is this? Where do you got it?Disable all network protocoll for SS2 and delete setup4pc from autostart. Quote
