Search for TV series
Tyro
I´ve just installed Recording Service and wonder how I can set up the service to search for TV-series and watch over and record every episode with just one search before the fist episode?
Some PVRs use series tags broadcast in Event Information Tables (EITs), but only a few networks send these, and they've not (so far) been implemented in DVBViewer.
Instead, you should save a Search Preset for the series, ticking the "Add to Auto-Record search" box. Then, whenever you run the "AutoTimer" task, any EPG matches will be used to create a new timer task.
To automate this, set up regular, successive timers for "EPG Update" and "Autosearch".
Edited by QBox User
