HDHomeRun Compatible yet ?
Hi.
Can you inform if DVBViewer is comaptible with the HDhomerun or if you plan to do so ?
Best Regards
Peter
Have you tried it ? According to the changelog it offers a BDA driver.
HDHomeRun BDA driver: Fix minor resource leak.
I tried it a year ago - but I guess it is time for a second try now, thanks ;)
Hi again.
I think DVBViewer still have problems with the HDhomerun.
If the whole transponder is unchecked, it still uses 50Mbit on the network from the HDhomerun - so the hardware handling still isnt optimal.
It also have problems releasing the tuners after use - which it never does when using Windows Media Center under Windows 7 ;(
Yes, it is somehow impossible for you to debug on this if the vendor do not reply - I also once wrote on their forum trying to get them to contact you, but their focus seems elsewhere.
I guess the solution is just getting another tuner, non networkish.
Thanks for the reply.
