javascript in firefox causes crashes
problems
I'm not really sure where to post this, I'm using the trial version of DVBViewer but it crashes if I have firefox opened alongside it and if I stumble upon a website which has javascript on it, which is pretty much every website. If i'm only listening to radio, then the sound starts screeching and I have to reopen the channel in order to get it back. What's frustrating is that no one else seems to be affected by this problem, is it possible that I'm the only one? I'm not a huge fan of DVBViewer but it's the only one that works ok with my card, well except for the fact that I cannot multitask while using it... If there's some easy solution for this?
Been using DVBViewer for about 3 years now ..... never come across your issues.
Try and download some recent codec packs.
I use Firefox a lot and again no issues.
In particular have a look at your audio settings, maybe try a different codec.
http://ct.download.com/clicks?t=1122829408-1db6584e3cffe2ee228f6b1ded0c410c-bf&brand=DOWNLOAD&s=5
Hope that helps.
