iPad/iPhone streaming
frankyshiu
Hi, when i using iPad streaming, it can't streaming "longer" time, streaming 1 to 3 mins only and got halt....
before 1.9 ver. without this problem. and i already tried difference ffmpeg ver. still dosent work....
Thanks
Edited by frankyshiu
try another ffmpeg preset. fast or ultrafast maybe
Thanks for reply, just tested fast or ultrafast, it can stream a little longer, ard 10 mins, but still halt later on.
do you have another solution ? what do you means of "another ffmpeg preset" ? or which one is better? it is just put "ffmpeg.exe into folder? any others need ?
btw,i tried almost 10 ver. on it, no matter 32 bit or 64 bit ver.....
appreciated your help and sorry for a lot of question.
Thanks
I have the same problem. Streaming stops (picture freezes) after about 5-30 minutes.
What I have noticed, that when streaming stops, tuner is stopped also. My tuner has a blue led indicating that reception is under way, and that blue light turns off when picture freezes. If after freezing I go on the iPad to stream control menu, then streaming is still on.
It looks like recording service - for some reason - stops the tuner, while streaming is still under way.
anyone can help ???
it seems latest rec 1.9.4.1 cause this problem.
I use ios 3.1.2 on Iphone 3, and v4.2.1 on Iphone 4, both stopped streaming after 10-15 minutes..
Before this, i could stream all day.
It seems that with rec 1.9.4.1, if i choose fast at encoding, stream is working good.
With default, medium, setting, stream broke.
I notice that same problem last weekend.
No, I cant say im suffering from that issue. However I have an another streaming issue with my iPhone 3GS OS version 4.0. It works streaming liveTV but streaming recordings from iPhone "Recordings" folder is broken. It works listing all recordings but when pressing on one, screen grays out and i cant navigate further from that point. Only way is to exit and log in again. Quite frustrating and there are no logs answering what went wrong. Strange thing is there is no problems streaming the very same recording from iPhone "Videos" folder if setting up reaching RS recordings folder from there.
Edited by majstang
stepped into that trap as well - the thing is, that the complete list is presented - if you scroll down to the end you arrive at the item you chose and can perform the desired action - a workaround is to select by date ie. year then month - that should narrow down the selection - but I agree the behaviour is not very convenient.
Yes, you are right! That workaround works great, thanks :) "By Channel", "By Date" and "By Series" works, then the streaming menu appears, but when listing the whole RS recording database in "All" and "By Genre" the menu fails. Wonder if perhaps a database error causes this or a RS iphone/iPad bug, or maybe something with ffmpeg. Seems strange anyhow.
Also discovered ffmpeg doesn't support unicode filenames :( Trying to stream the MPEG2: 20120318_00-04-00_TV4_Point break - ★★★★★★★★☆☆.ts
fails miserably. Menu appears, streaming initializes but gets stuck in loading mode. Unfortunately same deal for the flowplayer as well :(
Edited by majstang
Confirm, playing my recs on Iphone not working, it display triangle cut with an line, and also an message: template not prepared
And i could not stop stream server, i click on it, but do nothing, and im force to shutdown DVBViewer app
Edited by bogdan1980
  • 3 weeks later...
Unfortunately iphone/ipad streaming of recordings from recordings-->all folder is still problematic.
Streaming files with unicode file name works fantastic with both ffmpeg and the flowplayer. Great work :thumbsup:
why?
why?
I tried to describe the issue from post 9 in this thread. Pio and Bogdan1980 could confirm it, but i do not get the "template not prepared" message Bogdan1980 describes.
Edited by majstang
well it's not really useable because the list is much too long.
Might be time to switch the framework. The iWebkit stuff was ok 3 years ago but now it's just not that useable anymore...
Yes, i think you're right! I suppose the common thing for the three of us who could confirm the issue should be we all have a large recording database...i'm up to 700 now.
1266 and counting... Scrolling through this list to the end gives you real pain in the finger. ;)
Ha ha...yeah i did noticed the pain as well :rotfl:
I onlye have 40-50 recs and still have problems when watching on iphone.
Oh, sorry! I assumed you had the same issue as Pio and me. Seems yours is isolated. Could you describe how to reproduce it in more detail?
can some help me too... i still can't streaming TV smoothly, even upgrade to RC 1.9.5 , re-install and using difference of FFMPEG Version... any setting or important stuff i need to take care of it ??? where can i get the old one (1.9.2)?
frankyshiu, use fast or ultrafast in encoding settings on iphone or ipad.
majstang, i open iphone page, go to recs, all( OR by channel, by series, by genre, by date) , choose an rec, choose stream, and triangle cut with an line appear( that mean streaming not working)
Now i click on stop stream, an white page appear, with message: '' template not prepared"
Now i use Iphone button to exit the app.
In the logs i see :
18.04.12 11:14:02.174 SetThreadExecutionState 0x80000000
18.04.12 11:14:02.174 Releasereference webserver: 0
18.04.12 11:14:14.362 TEPGUpdater Allocate BDA 2885 TVTuner C (7)
18.04.12 11:14:14.362 TEPGUpdater Release BDA 2885 TVTuner C (7)
No error, nothing.
Thanks for your reply, but RC default is ultrafast in 1.9.5... so...
i tried all of FFMPEG present from slow to ultrafast, can only stream like 30 mins or something...
No error, nothing.
iPhone version? iOS version? Does it work without issue streaming the same recordings with your iPhone 3G? If it has worked earlier from which RS version did the problem appear? Does the issue resemble Stigjohan76's problem with broken playbutton? http://www.DVBViewer.tv/forum/topic/38858-iphoneipod-touch-support/page__view__findpost__p__351525
Have you tried with playing around with different bitrates? Do you stream over 3G or wifi when it stops? You see if streaming over 3G and using the highest bitrate of "High 2048 kbit" you're in for trouble, even if using "ultrafast" encoding. Test with the lowest bitrate available, ultrafast and see how it goes.
Actually i just used for my bedroom, it's wifi only. also i tried different "bit" and present , still....
But today, can streaming more than 2 hours without problem after installed k-lite mega code 8.6 .....
it is any related ??? is all about coding issue? my PC win7 intel i5 , 100m ISP and router TP-link 1043 ND.
Thanks again.... appreciated your help
unfortunately, still halt after 3 hours....... :( :( :( :( :( :( :(
Nightmare
Nightmare
Check your energysavings settings for the network card. Go over the wifi settings for the router as well (do not know much about that TP-link router).
On my crappy Iphone 3 and 4, after 30 minutes WIFI dissapear even if im near my dlink router and with full signal.
I have this problem forever, from the first day i use an Iphone.
I think that Apple& MY ISP named ORANGE disable WIFI because they want(force us) to use 3G.
My WIFI disabled if im watching youtube, stream tv from DVBViewer, use safari, etc.
I have 3g with 3.1.2 and Iphone 4 with 4.3.X ( or something)
I think i fixed problem with Broken play button, videos( recs) not playing because they did not exist at all, i do an rebuild video library an all my videos( recs) dissapear( i think they all was deleted on my hdd a long time ago).
That why i see Template not ready message.
I execute an experiment, open Iphone, DVBViewer webpage, programming an rec, to see if its working on Iphone, and i can say its working, the recs play ok on my Iphone.
I choose recs-all.
i can only put my hope to next update... problems still there...
nightmare since changed using current ffmpeg :(
after del 2 files in config... still can't work smoothly, stop streaming after 1 or 2 hours...... any another suggestion ?
Your svcdebug.log does not contain any ffmpeg logs where the problem might be found. Perhaps if you do iphone streaming until it fails and THEN make a support.zip and post it?
I made it after failed of streaming 3 times last night...
no log ? actually i have no idea on it.
just check, it should be there... but i don't know how to check problem inside "svcdebug.log"
anyone can help me ???
btw, i will change "stronger router tonight" ASUS rt-n66u, hopefully will solve it.. :(
Yes, svcdebug.log is there but it doesn't contain any FFMPEG loggings. You are using Win7 64-bit, make sure to download the FFMPEG for 64-bit and exctract it. Delete the FFMPEG.exe in the DVBViewer folder and copy the newly extracted one into same folder. Don't know if using FFMPEG.exe 32-bit on a 64-bit system can cause such problems the logs not showing up in svcdebug.log.
When checking your support.zip you seem to be using the Netstreaming plugin and I wonder why? That one isn't needed with RS and might be causing the problems you're experiencing.
Edited by majstang
should i remove net streaming ?
any special here :
24.04.12 22:37:43.883 FFMPEG frame=19631 fps= 25 q=24.0 size= 0kB time=00:13:04.82 bitrate= 0.0kbits/s dup=17 drop=0
24.04.12 22:37:44.083 Split 5179
24.04.12 22:37:44.414 FFMPEG frame=19646 fps= 25 q=24.0 size= 0kB time=00:13:05.40 bitrate= 0.0kbits/s dup=17 drop=0
24.04.12 22:37:44.937 FFMPEG frame=19659 fps= 25 q=33.0 size= 0kB time=00:13:05.97 bitrate= 0.0kbits/s dup=17 drop=0
24.04.12 22:37:45.433 FFMPEG frame=19671 fps= 25 q=28.0 size= 0kB time=00:13:06.40 bitrate= 0.0kbits/s dup=17 drop=0
24.04.12 22:37:45.959 FFMPEG frame=19685 fps= 25 q=28.0 size= 0kB time=00:13:06.93 bitrate= 0.0kbits/s dup=17 drop=0
24.04.12 22:37:46.532 FFMPEG frame=19699 fps= 25 q=29.0 size= 0kB time=00:13:07.51 bitrate= 0.0kbits/s dup=17 drop=0
24.04.12 22:37:47.004 FFMPEG frame=19712 fps= 25 q=29.0 size= 0kB time=00:13:08.08 bitrate= 0.0kbits/s dup=17 drop=0
24.04.12 22:37:47.548 FFMPEG frame=19725 fps= 25 q=29.0 size= 0kB time=00:13:08.49 bitrate= 0.0kbits/s dup=17 drop=0
24.04.12 08:32:39.788 Count 4
is it these causing stop ?
log size too big, i can't upload here ... it stop streaming @ 22:53 , i found the following log :
24.04.12 22:52:19.979 Split 5008
24.04.12 22:52:20.336 FFMPEG illegal short term buffer state detected
frame=41550 fps= 25 q=33.0 size= 0kB time=00:27:41.49 bitrate= 0.0kbits/s dup=43 drop=0
24.04.12 22:52:20.894 FFMPEG frame=41564 fps= 25 q=33.0 size= 0kB time=00:27:42.07 bitrate= 0.0kbits/s dup=43 drop=0
24.04.12 22:52:21.510 FFMPEG frame=41577 fps= 25 q=33.0 size= 0kB time=00:27:42.67 bitrate= 0.0kbits/s dup=43 drop=0
24.04.12 22:52:21.887 FFMPEG frame=41589 fps= 25 q=33.0 size= 0kB time=00:27:43.05 bitrate= 0.0kbits/s dup=43 drop=0
24.04.12 22:52:22.471 FFMPEG frame=41601 fps= 25 q=32.0 size= 0kB time=00:27:43.65 bitrate= 0.0kbits/s dup=43 drop=0
24.04.12 22:52:22.995 FFMPEG frame=41615 fps= 25 q=28.0 size= 0kB time=00:27:44.18 bitrate= 0.0kbits/s dup=43 drop=0
24.04.12 22:52:23.497 FFMPEG frame=41630 fps= 25 q=29.0 size= 0kB time=00:27:44.76 bitrate= 0.0kbits/s dup=43 drop=0
24.04.12 22:52:24.002 FFMPEG frame=41637 fps= 25 q=24.0 size= 0kB time=00:27:45.19 bitrate= 0.0kbits/s dup=43 drop=0
24.04.12 22:52:24.269 TUCCommandClient DelPid: 831 832 0 830 1001
24.04.12 22:52:24.269 TUCCommandClient Addpid: 851 852 0 850
24.04.12 22:52:24.409 TUCCommandClient Addpid: 855
24.04.12 22:52:24.410 TUCCommandClient Addpid: 1001
24.04.12 22:52:24.518 FFMPEG frame=41651 fps= 25 q=31.0 size= 0kB time=00:27:45.72 bitrate= 0.0kbits/s dup=43 drop=0
24.04.12 22:52:25.064 FFMPEG frame=41666 fps= 25 q=30.0 size= 0kB time=00:27:46.29 bitrate= 0.0kbits/s dup=43 drop=0
any idea of it ?????
