iPad/iPhone streaming
frankyshiu
should i remove net streaming ?
Do you know when and why you did install the netstreaming plugin? Yes, i think you should remove it, cuz RS takes care of all the streaming you need and you will avoid potential conflicts.
Then post a new support.zip and let me know the exact time when iphone streaming failed.
If nothing else works i think you should start from scratch, cuz your setup seems to be a mess. Starting all over again could often be the biggest timesaver. All the codecs you have points to usage of codec-packs, which can cause directshow havoc by itself. I think you did mention something about codecs before and how that affected the streamtime in a positive manner. It is enough with installing the Powerdvd codecs and to keep far away from these "evil" codec-packs ;)
just upload support.zip to freakshare coz size more than 1M, can't upload here
http://freakshare.com/files/dolbagff/support.zip.html
Thanks for you help.
It stop streaming ~00:30
25.04.12 00:30:18.818 tStreamClient Release 7160 BDA DMB-TH Tuner
25.04.12 00:30:18.818 tStreamClient Destroy 7160 BDA DMB-TH Tuner
25.04.12 00:30:18.847 tStreamClient Destroyed 7160 BDA DMB-TH Tuner
25.04.12 00:30:18.847 tStreamClient hamDeleted 7160 BDA DMB-TH Tuner
25.04.12 00:30:18.847 ReleaseStandbyblock TStreamClient
25.04.12 00:30:18.847 SetThreadExecutionState 0x80000000
25.04.12 00:30:18.847 Releasereference TStreamClient: 0
25.04.12 00:52:59.673 Count 77
25.04.12 00:53:09.767 SetStandbyblock webserver
25.04.12 00:53:09.767 SetThreadExecutionState 0x80000041
25.04.12 00:53:09.767 AddReference webserver: 1
25.04.12 00:53:09.964 Count 76
25.04.12 00:53:31.125 Count 75
25.04.12 00:53:51.798 Count 74
25.04.12 00:54:14.109 Count 73
25.04.12 00:54:34.767 Count 72
25.04.12 00:54:55.928 Count 71
25.04.12 00:55:17.777 Count 70
25.04.12 00:55:40.479 Count 69
25.04.12 00:56:00.480 Count 68
25.04.12 00:56:23.169 Count 67
25.04.12 00:56:44.031 Count 66
25.04.12 00:57:04.912 Count 65
Edited by frankyshiu
actually just installed K-lite mega code pack which support for RMVB,RM etc...
PowerDVD can't handle all of these stuff..
No, sorry the log looks perfectly normal and gives no clues to why the iphone streaming stops for you.
including this ???
25.04.12 06:44:03.035 AddReference CMDClientConnect: 3
25.04.12 06:44:03.036 TUCCommandClient Set Tuner
Tunertype: 2, Frequency: 586000, Symbolrate: 0, LNB: 0, Selection: 0, Polarity: 2, DiseqC: 3, FEC: 0, AudioPID: 832, VideoPID: 831, PMT: 830, SID: 83, SatModulation: 0, DiseqCValue: 0, NID: 32766, Flags: 24
25.04.12 06:44:03.036 TUCCommandClient AllocateHardware 7160 BDA DMB-TH Tuner
25.04.12 06:44:03.036 TUCCommandClient got Hardware
25.04.12 06:44:03.036 TUCCommandClient Set the tuner
25.04.12 06:44:03.041 TUCCommandClient Addpid: 18
25.04.12 06:44:03.062 TUCCommandClient Addpid: 831 832 0 830
25.04.12 06:44:03.063 FFMPEG frame=66861 fps= 25 q=22.0 size= 0kB time=00:44:33.96 bitrate= 0.0kbits/s dup=17 drop=0
25.04.12 06:44:03.257 Split 5195
25.04.12 06:44:03.439 TUCCommandClient Addpid: 1001
25.04.12 06:44:03.647 FFMPEG frame=66873 fps= 25 q=22.0 size= 0kB time=00:44:34.53 bitrate= 0.0kbits/s dup=17 drop=0
25.04.12 06:44:04.195 FFMPEG frame=66890 fps= 25 q=20.0 size= 0kB time=00:44:35.06 bitrate= 0.0kbits/s dup=17 drop=0
25.04.12 06:44:05.596 FFMPEG frame=66900 fps= 25 q=18.0 size= 0kB time=00:44:35.44 bitrate= 0.0kbits/s dup=17 drop=0
25.04.12 06:44:06.094 FFMPEG PES packet size mismatch
[ac3 @ 0000000001da75d0] frame CRC mismatch
[h264 @ 000000000378d310] cabac decode of qscale diff failed at 44 28
[h264 @ 000000000378d310] error while decoding MB 44 28, bytestream (6544)
[h264 @ 000000000378d310] concealing 365 DC, 365 AC, 365 MV errors
[ac3 @ 0000000001da75d0] frame sync error
Error while decoding stream #0:1
frame=66938 fps= 25 q=13.0 size= 0kB time=00:44:36.98 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:06.618 FFMPEG frame=66950 fps= 25 q=16.0 size= 0kB time=00:44:37.56 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:07.141 FFMPEG frame=66965 fps= 25 q=20.0 size= 0kB time=00:44:38.13 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:07.663 FFMPEG frame=66978 fps= 25 q=15.0 size= 0kB time=00:44:38.52 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:08.222 FFMPEG frame=66991 fps= 25 q=15.0 size= 0kB time=00:44:39.09 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:08.437 Split 5179
25.04.12 06:44:08.708 FFMPEG frame=67004 fps= 25 q=19.0 size= 0kB time=00:44:39.67 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:09.204 FFMPEG frame=67016 fps= 25 q=16.0 size= 0kB time=00:44:40.08 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:09.753 FFMPEG frame=67030 fps= 25 q=14.0 size= 0kB time=00:44:40.63 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:10.313 FFMPEG frame=67043 fps= 25 q=19.0 size= 0kB time=00:44:41.20 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:10.801 FFMPEG frame=67055 fps= 25 q=14.0 size= 0kB time=00:44:41.78 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:11.322 FFMPEG frame=67067 fps= 25 q=17.0 size= 0kB time=00:44:42.19 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:11.892 FFMPEG frame=67081 fps= 25 q=18.0 size= 0kB time=00:44:42.74 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:12.402 FFMPEG frame=67094 fps= 25 q=18.0 size= 0kB time=00:44:43.32 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:12.961 FFMPEG frame=67109 fps= 25 q=25.0 size= 0kB time=00:44:43.89 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:13.459 FFMPEG illegal short term buffer state detected
frame=67121 fps= 25 q=32.0 size= 0kB time=00:44:44.47 bitrate= 0.0kbits/s dup=42 drop=0
25.04.12 06:44:13.627 Split 5179
so... time to giveup DVBViewer RS ???
You could try this: Dvblink trial ( creates virtual tuner) into mediacenter.
Then use their service to stream to Iphone. Quite complicated at first but you get used to it in few days.
Their iphone webpage is quite spartan( basic) but it's workin for stream.
If it's working then you do something wrong in DVBViewer.
1 year ago iphone stream from Dvblink was better then DVBViewer, stream more fluid, but time change, now DVBViewer is king.
Maybe you need to do an IOS restore, fresh windows, etc
Also, you could use an older DVBViewer version + an older rec service to test( if you have old setups backup up somewhere)
One more thing: if your on win 7, look to see if you have another dvb app installed, and shut down their services( mediacenter services, progdvb scheduler service, mediaportal, etc)
Till few month ago i was havin an problem, after few hours stream broke, image freeze on DVBViewer + iphone stream.
I just shut down mediacenter services + dvblink service and all was good
reinstall + changed router to ASUS rt n66U + remove code pack , still got the problems there, everythime will stop streaming when following log exsit :
[h264 @ 00000000003216f0] non-existing SPS 0 referenced in buffering period
[h264 @ 00000000003216f0] non-existing PPS referenced
[h264 @ 00000000003216f0] non-existing PPS 0 referenced
[h264 @ 00000000003216f0] decode_slice_header error
[h264 @ 00000000003216f0] no frame!
[h264 @ 00
28.04.12 08:34:24.090 Release 7160 BDA DMB-TH Tuner
28.04.12 08:34:28.094 FFMPEG 000000003216f0] decode_slice_header error
[h264 @ 00000000003216f0] mmco: unref short failure
Last message repeated 1 times
[h264 @ 00000000003216f0] Increasing reorder buffer to 1
[mpegts @ 00000000002ff660] max_analyze_duration 5000000 reached at 5024000
Input #0, mpegts, from 'http://192.168.1.100:7522/upnp/channelstream/1.ts':
Duration: N/A, start: 50073.307233, bitrate: N/A
Program 83
Stream #0:0[0x33f]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 720x576 [sAR 16:11 DAR 20:11], 27.17 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x340]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, s16, 128 kb/s
[buffer @ 00000000003ac1e0] w:720 h:576 pixfmt:yuv420p tb:1/1000000 sar:16/11 sws_param:flags=2
[yadif @ 00000000003ac2a0] mode:0 parity:-1 auto_enable:1
[scale @ 00000000003ac300] w:720 h:576 fmt:yuv420p sar:16/11 -> w:720 h:394 fmt:yuv420p sar:197/198 flags:0x4
[libx264 @ 0000000002c2c500] VBV maxrate unspecified, assuming CBR
[libx264 @ 0000000002c2c500] using SAR=197/198
[libx264 @ 0000000002c2c500] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
[libx264 @ 0000000002c2c500] profile Constrained Baseline, level 3.0
[mpegts @ 00000000003b9510] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to '\\.\pipe\Output{BD4851FE-2DA6-43FA-867C-A68F28B20282}':
Metadata:
encoder : Lavf54.3.100
Stream #0:0: Video: h264, yuv420p, 720x394 [sAR 197:198 DAR 20:11], q=-1--1, 1700 kb/s, 90k tbn, 25 tbc
Stream #0:1: Audio: mp3, 48000 Hz, stereo, s16, 192 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (h264 -> libx264)
Stream #0:1 -> #0:1 (ac3 -> libmp3lame)
Press [q] to stop, [?] for help
[h264 @ 000000000368e320] Missing reference picture
[h264 @ 000000000368e320] decode_slice_header error
[h264 @ 000000000368e320] concealing 1620 DC, 1620 AC, 1620 MV errors
[h264 @ 00000000036d50f0] Missing reference picture
[h264 @ 00000000036d50f0] decode_slice_header error
[h264 @ 00000000036d50f0] concealing 1620 DC, 1620 AC, 1620 MV errors
[h264 @ 0000000003734ba0] Missing reference picture
[h264 @ 0000000003734ba0] decode_slice_header error
[h264 @ 0000000003734ba0] concealing 1620 DC, 1620 AC, 1620 MV errors
[h264 @ 00000000036d50f0] mmco: unref short failure
anyone can help me?? my main function of DVBViewer is for streaming TV to my ipad.....coz no TV signal in my bedroom....
really appreciated if someone can help me..
just found another log casing my RC stop streaming.....
29.04.12 03:16:52.799 FFMPEG frame=24267 fps= 25 q=2.0 size= 0kB time=00:16:10.15 bitrate= 0.0kbits/s dup=23 drop=0
29.04.12 03:17:08.354 tStreamClient Release 7160 BDA DMB-TH Tuner
29.04.12 03:17:08.354 tStreamClient Destroy 7160 BDA DMB-TH Tuner
29.04.12 03:17:08.383 tStreamClient Destroyed 7160 BDA DMB-TH Tuner
29.04.12 03:17:08.383 tStreamClient hamDeleted 7160 BDA DMB-TH Tuner
29.04.12 03:17:08.383 Releasereference TStreamClient: 1
any idea fix it ????
It can be anything. Receiving problems which cause trouble with ffmpeg for example. fact is, ffmpeg stops transcoding by itself. There is nothing the RS can do about it.
You could try the ffmpeg version dated 26.12.2011 http://ffmpeg.zeranoe.com/builds/win32/static/ffmpeg-git-f514695-win32-static.7z (for 32bit Windows) or http://ffmpeg.zeranoe.com/builds/win64/static/ffmpeg-git-f514695-win64-static.7z (64bit Windows). Maybe this helps.
Thanks again, still doesn't works unfortunately. maybe i need to buy a new pc....
really appreciated your help. i know is my PC problems.
but may i ask for 1 questions more? is it any coding/program conflict with ffmpeg?
Thanks
