Runtime error 217
entrecour
I am having a problem with playing some HD channels since changing a user account from Administrator to Standard User and enabling UAC. Before making the user account and UAC changes I had no problems with HD channels.
Most of the time the HD channel does not play (no video or audio) although they seem to tune (according to the info in the status bar). One HD channel plays consistently without problems. All SD channels play without any probems.
On one channel (BBC HD) DVBViewer closes with Runtime error 217 at 05AAD366.
Support file attached...
I have found the following errors in Event Viewer
Log Name: Application
Source: Microsoft-Windows-CAPI2
Date: 3/10/2012 2:02:34 PM
Event ID: 11
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: HTPC-1
Description:
Failed extract of third-party root list from auto update cab at: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootstl.cab> with error: A required certificate is not within its validity period when verifying against the current system clock or the timestamp in the signed file.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-CAPI2" Guid="{5bbca4a8-b209-48dc-a8c7-b23d3e5216fb}" EventSourceName="Microsoft-Windows-CAPI2" />
<EventID Qualifiers="49154">11</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-03-10T13:02:34.000Z" />
<EventRecordID>137176</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>HTPC-1</Computer>
<Security />
</System>
<EventData>
<Data>http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootstl.cab</Data>
<Data>A required certificate is not within its validity period when verifying against the current system clock or the timestamp in the signed file.
</Data>
</EventData>
</Event>
Source: Application Error
Date: 3/10/2012 1:55:51 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: HTPC-1
Description:
Faulting application DVBViewer.exe, version 4.9.0.0, time stamp 0x2a425e19, faulting module CoreAVCDecoder.ax, version 2.6.2.0, time stamp 0x4e69658e, exception code 0xc0000005, fault offset 0x00027dd5, process id 0x1e24, application start time 0x01ccfebd0c9001a0.
Event Xml:
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<TimeCreated SystemTime="2012-03-10T12:55:51.000Z" />
<EventRecordID>137172</EventRecordID>
<Security />
</System>
<EventData>
<Data>DVBViewer.exe</Data>
<Data>4.9.0.0</Data>
<Data>2a425e19</Data>
<Data>CoreAVCDecoder.ax</Data>
<Data>2.6.2.0</Data>
<Data>4e69658e</Data>
<Data>c0000005</Data>
<Data>00027dd5</Data>
<Data>1e24</Data>
<Data>01ccfebd0c9001a0</Data>
</EventData>
</Event>
Source: DVBVRecorder
Date: 3/10/2012 1:54:44 PM
Event ID: 0
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: HTPC-1
Description:
The description for Event ID 0 from source DVBVRecorder cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Recording service stop
Event Xml:
<System>
<Provider Name="DVBVRecorder" />
<EventID Qualifiers="0">0</EventID>
<Level>4</Level>
<Task>0</Task>
<TimeCreated SystemTime="2012-03-10T12:54:44.000Z" />
<EventRecordID>137170</EventRecordID>
<Security />
</System>
<EventData>
<Data>Recording service stop</Data>
</EventData>
</Event>
I have tried LAV but it doesn't help. IMHO this is something to do with the change to Standard User and enabling UAC but I don't see why it should only affect HD channels.
I uninstalled DVBViewer and RS, deleted the data directory, deleted leftover registry keys, and reinstalled, installed latest DVBSource, then scanned and regenerated my channel list. Now everything works OK again - I just have to find and reinstall - my movies, all my channel logos and an osd skin.
As an improvement suggstion it strikes me that for the next version the DVBViewer installer could be revised e.g.
Why have webstreamer (?) in the install when RS is available?
Why not include RS as part of the install flow and include a preconfiguration for DVB and RS on same PC?
Add dvbsupporttool install as option or standard part of flow.
Add transedit as install option.
Add mymovies plugin to DVBViewer (and take over maintainance)
Thanks.
Edited by entrecour
