Seeking Remote control plug in for Magic-Pro ProHDTV Diamond 2 in Hong
Dear All,
The driver of Remote control for Magic-Pro ProHDTV Diamond 2 is here http://www.magic-pro.com/driver/ProHDTV/Diamond2.htm.
I have tried to use learn function to setup the remote for DVBViewer. However, there is no respond when I press button in the control. Is there any plug in could be developed for this remote?
Thanks for all your help.
fbj
Hello,
it seems the remote works with WMC too. Try the wmc plugins from members area.
Hello,
Thank you.
I have download the file myMCE2005.dll and myMCEIr.dll to Plugins folder. I selected it in the option and tick the myMCE2005 and Then try to tick myMCEIr. However, DVBViewer can't learn the button. So, what should I do further.
Thanks for your help.
