Dvico Fusion HDTV5 USB Gold (Bluebird BDA Tuner)
Keithk
I installed DVBViewer Pro 4.8.1.0 and it works fine with my
Satellite Tuner card ( TBS 9925)and it reconizes my
USB Off Air Tuner- Dvico Fusion HDTV5 USB Gold (Bluebird BDA Tuner)
but when I do a channel scan it finds nothing.
any suggestions ?
Please download the new version 4.9.5.0, old versions are no longer supported
Here is a snapshot of the Scan Screen
Maybe this wil help, it shows a Green Bar for Signal,
but no channels found..
In your support.zip I see
<entry name="Name">Bluebird, BDA Tuner1 (2)</entry>
<entry name="TunerType">2</entry>
TunerType 2 is DVB-T, but your screenshot shows "Reception Type ATSC". Doesn't match. So I guess you want to receive ATSC, but it can't work since your device has been detected as DVB-T. Maybe setting it manually to ATSC in the hardware options helps...
I must have been trying many options and forgot to correct it before
upoading the file..
fixed that.. still no good
entry name="LowBandWidth">1</entry>
<entry name="UseHardwareFilter">1</entry>
<entry name="StopStream">1</entry>
<entry name="NoStandard">1</entry>
<entry name="useMSNP">1</entry>
<entry name="TunerType">3</entry>
<entry name="Status">1</entry>
<entry name="InstID">Bluebird, BDA Tuner1 1</entry>
<entry name="DeviceNr">2</entry>
<entry name="Vendor">0</entry>
<entry name="Priority">2</entry>
<entry name="Tag">0</entry>
<entry name="ClassID">{EAFB3270-65C7-4662-99D6-C06D5E009FA3}</entry>
<entry name="Groups">255</entry>
<entry name="Retune">5</entry>
<entry name="SkipComponents">0</entry>
Does it work if you switch "Direct Tuning" off?
I'll give that a try...
thanks
Edited by Keithk
It's an old bug that is fixed in the current DVBViewer release. When passing the frequency to the driver a 1750 khz offset has to be subtracted. In older versions only the "Direct Tuning off" mode does it correctly.
