rizik29 Posted March 19, 2012 Posted March 19, 2012 In the information about new DVBViewer 4.95 it says "The DVBServer has been discontinued and will be no longer available.". This is a great tool that I use often. Is there any replacement for it, or will newer versions of DVBViewer support older version of DVB Server? Quote
Tjod Posted March 19, 2012 Posted March 19, 2012 Is there any replacement for it?Yes the Recording Service.http://en.DVBViewer.tv/wiki/DVBViewer_Recording_Service http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide Quote
rizik29 Posted March 19, 2012 Author Posted March 19, 2012 Thanks for reply. I've made some tests with following results: - DVB Server 4.9.0 works ok with DVBViewer 4.9.5 - DVB Recording Service in portable format (I don't like installing unnecessary services on windows so I made this service portable) also works as DVB Server (DVB Server is integrated into it) I don't like integration of DVB Server into a service. It works well as a standard standalone application and should be left that way. Its function has nothing to do with recording and it is wrong approach. Quote
mr_chaela Posted March 20, 2012 Posted March 20, 2012 Just install 4.9.5/4.9.5.1 as an update over a 4.9.0 installation and DVBServer will still be there to use. Quote
