TransEdit LNB switch off
dolehaj
I would really appreciate functional LNB switch off in TransEdit similar to DVBViewer. Would it be possible to add this feature here too?
Thanks and keep up your perfect work. :thumbsup:
d.
LNB off can be activated by a tweak:
1) Close TransEdit. Open the file TransEdit.ini (see Info -> Configuration Folder) with a text editor.
2) Find the entries for your TT 3200 in the [Hardware] section and insert the line
LNBOff.x=1
where x is the card's device number (must be the same as for other TT 3200 entries).
3) Save, re-launch TransEdit and try.
Please note: The AutoLNBOff entry tells TransEdit whether a card automatically switches the LNB power off when not used. It must be = 0 for the TT 3200. Otherwise TransEdit will do nothing for LNB off, because it assumes it doesn't have to.
Great, it works! I'm really satisfied, oh man, thank you! :beer:
  • 5 weeks later...
LNBOff.x=1
Unfortunately this tweak always is removed from .ini file after any accepted change in Settings of TransEdit.
