Problem with tbsciapi.dll 1.0.0.8
ccristal
Hi!
Since I installed the latest version of TbsCIapi.dll (1.0.0.8) in my DVBViewer, my QBOX CI doesn't turn off when I close the DVBViewer window - the front LED remains blue. When I stop the recording service, instead, everything works as it should -> the blue led turns red.
Reverting to v1.0.0.7 fixes the problem: as soon as I close the DVBViewer window, the QBOX CI turns off normally.
Initially, I thought the problem was in the dll, but thinking about it I realised that, if that were the case, it shouldn't have worked when stopping the RS either.
Here's my setup:
TBS5980 driver version: 1.0.2.6 for Windows 7-x64
DVBViewer version: 4.9.5.1
DVBViewer Recording Service v1.9.4.1
This also happened with DVBViewer 4.9.0.0 and RS 1.9.4.1.
Any idea?
Let me know if you need a support.zip.
Thank you for your attention and your help.
ccristal
  • 8 months later...
hi
I've got my Technotrend S2-3200 HDTV-S2 + compatible CI module TViewer tv card there and it got it. DVBViewer using the latest version of the license. dsmart XP operating system, a module of the card read. no problem. but it did not do the same thing in windows 7 waiting for your help in this regard thanks
hi
I've got Technotrend S2-3200 HDTV-S2 and CI module.
I'm use latest version of DVBViewer.
I've got a problem. I'm bought d-smart nds module and subscription card. This module is working with DVBViewer under Windows Xp Os but not working under Windows 7 Os.
I haven't got any idea for this problem and I need your help.
Best regards,
Emin ...
