screen resolution 4.9.5.1
After installing DVBviewer4951 into the same folder as DVBviewer490, any TV channel broadcasting at 1440 by 1088 if filling up most of a 1920 by 1200 monitor screen, this happens across different TV channels (BBc1 HD, CH4 HD etc).
This still works fine off another DVBViewer on the same PC running 490.
Tried different Skins but no change. (Zooming to 100% in all cases)
Have I missed something ?? Anyone else have the same issue. Running PowerDVD12.
Frank
Edited by fxv1
did you check the aspectratio settings?
Hi Lars, yes tried most options in Aspect ratio.
At present using Auto. Tried Autosize on and off, same with Best Width.
Where are the setting held in case I have a corrupt file ? Maybe a fresh install.
Thanks
Frank
sorry I had not tested the aspect ratio when set to NONE which displays correctly.
Sorry to have wasted your time.
Frank
