defcon5 Posted March 29, 2012 Posted March 29, 2012 (edited) Hi everybody From 2 day ago, I changed internet connection from ADSL to FTTH, and now I have another router. I use DVBViewer with Recording service (RS) and with the olds routers never I have had problems with DVBViewer but now when I start DVBViewer, a seconds after I lost de internet signal in my HTPC only, the rest of stations laptop (with LAN ) and Desktop office (with wifi) take the internet signal without problems. This issue occurs also, if I start DVBViewer client from other PC but only lost the internet connection my HTPC with DVBViewer server and RS installed. I never have open before ports in the olds routers ADSL for use DVBViewer. Anybody knows where can be the problem? Do I need open ports in my new roter? what ports? If you need mor information please tell me Thaks in advance Edited March 29, 2012 by defcon5
defcon5 Posted March 30, 2012 Author Posted March 30, 2012 FIXED !! The guilty was a problem of conflict IRQ between a card dual tuner DVB-T and the port LAN Ethernet on my motherboard. If disable the card all ok. Sorry, and I hope this help somebody than occurs similar issue Thanks
