majstang Posted March 31, 2012 Posted March 31, 2012 (edited) I have a peculiar issue i can't explain. Some recordings simply doesn't show up in the recordings database either when rebuilding or clean and refreshing db, despite all files (dummy.ts, .txt and .log) seem to be correct. Can't spot the error anywhere. RS 1.9.4.1 Here's two examples: Edited March 31, 2012 by majstang
Lars_MQ Posted March 31, 2012 Posted March 31, 2012 The log is not really needed. the info (txt) file should contain at least these fields or the recording will not be added. [General] Version=1.1 [Media] Channel=Syfy [0] Date=30.03.2012 Time=16:10:00 Duration=00:45:00 Title=Crusade
majstang Posted March 31, 2012 Author Posted March 31, 2012 The log is not really needed. Yes, i know, but I like to keep it around to be abled to track timings of errors and discontinuities in the recording. the info (txt) file should contain at least these fields or the recording will not be added. These fields are present in both (txt) and they dont show up regardless and I cant understand why really. If I remember it right I think the thing in common for these two recordings was they was started through the RS Timeline (some time past the actual starttime) and not as timers. [General] Version=1.1 [Media] Created=24.03.2012 22:21:27 Channel=Animal Planet [0] Id=203242155 Date=24.03.2012 Time=21:55:00 Duration=00:55:00 Title=Animal Planets mest spektakulära Info=E02 Series= Description=Hemma hos djuren. Se USA:s mest fascinerande, konstiga och luxuösa lyor, rum och bon, bland annat ett mushus av bröd och en vindsvåningssvit för ankor. Del 2. Charset=255 Content=0 MinimumAge=0 TimerID={47E2B084-A286-463C-A7B0-5DFF86E5A1F0} [stats] Errors=0 Size=922,20 MB (966998680 bytes) Avr. Datarate=0,520 MB/s Device=FireDTV BDA Tuner DVBC (2) [General] Version=1.1 [Media] Created=24.03.2012 21:02:35 Channel=Animal Planet [0] Id=203242100 Date=24.03.2012 Time=21:00:00 Duration=00:25:00 Title=Karina på safari Info=E13 Series= Description=Karina är på safari i Zimbawbe och Zambia och ser stora elefanthannar, flodhästar, vildhundar och lejon i deras naturliga miljö. Del 13. Charset=255 Content=0 MinimumAge=0 TimerID={1B1C5A0B-66A8-4601-AF07-045BF6730F5E} [stats] Errors=0 Size=724,21 MB (759388964 bytes) Avr. Datarate=0,515 MB/s Device=FireDTV BDA Tuner DVBC (2)
Lars_MQ Posted March 31, 2012 Posted March 31, 2012 If you use charset=255 the fields Channel, Title,Info and Description MUST be UTF-8 encoded. Otherwise you should use Charset=1.
majstang Posted March 31, 2012 Author Posted March 31, 2012 All txt:s in the database is UTF-8 without BOM, including these ones. Jeez, this was peculiar, the problem seem to be filename related. RS did name it: D:\TV\Recording Service\20120324_22-21-27_Animal Planet_Animal Planets mest spektakulära_E02.ts Despite my File naming scheme is set to: %year%m%d_%time_%station_%event - %title The filename should have been: D:\TV\Recording Service\20120324_22-21-27_Animal Planet_Animal Planets mest spektakulära - E02.ts When manually removing the last underscore in the filename for both .ts and .txt and replacing it with " - " the file shows up when refreshing the db. Hmm...that was strange! I have no idea how this could have happened...i'll have to test to see if i could find something. regards majstang
majstang Posted March 31, 2012 Author Posted March 31, 2012 (edited) Oops... RS on my 64-bit system was still set to using the underscore and the two recordings were made by that system. Sorry for wasting your time A bit strange though such a small deviation can prevent the recording from showing up in the joint database. Edited March 31, 2012 by majstang
