ECM editing
Likvid
I need to manually add ECM PID to some channels, is it possible with DVBViewer?
You can do it in DVDDream, SmartDVB etc...
Not possible, not needed.
I wouldn't ask if it was not needed. :rolleyes:
Edited by Likvid
It is the part of CAM and the smartcard to select the correct ECM.
No, it's for handling special feeds for downlink which needs ECM to be put in manually.
