V_G Posted April 5, 2012 Posted April 5, 2012 Dear All, I've searched forum and cant find proper solution. I have 3 DVB cards (1 dual and 1 solo) and RS installed. I can watch two different programs one using RS service via http and one using DVBViewer but when I try to watch second programme using RS (http) on second computer only one works perfectly. What did I wrong or what I should do to watch using streaming on 2 or more computers? (if it is possible at all) thx in advance
Lars_MQ Posted April 5, 2012 Posted April 5, 2012 Please post some more information: http://www.DVBViewer.tv/forum/index.php?showtopic=2210
V_G Posted April 6, 2012 Author Posted April 6, 2012 (edited) Sorry, I din't read this post, please find attached detailed info P.S. thx for prompt reply support.zip Edited April 6, 2012 by V_G
Tjod Posted April 6, 2012 Posted April 6, 2012 You have set the TechnoTrend BDA/DVB-S in the Recording Service to don't use. So you can't use this card via Recording Service. The Windows Media Center Receiver Service is running on your system, it will block a card from time to time. Disable able it in windows. http://www.sevenforums.com/tutorials/2495-services-start-disable.html And than you need to disable all real cards in DVBViewer Pro and replace them with a unicast device. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide
V_G Posted April 6, 2012 Author Posted April 6, 2012 You have set the TechnoTrend BDA/DVB-S in the Recording Service to don't use. So you can't use this card via Recording Service. Yes and I did it on purpose, I turned on DVBViewer to check if I can watch two programs (dual DVB card) at the same time. ussually I dont use DVBViewer on this computer because I treat it as a server (not client&server). But anyway following you suggestion i did it - no change. The Windows Media Center Receiver Service is running on your system, it will block a card from time to time. Disable able it in windows. http://www.sevenforums.com/tutorials/2495-services-start-disable.html . done And than you need to disable all real cards in DVBViewer Pro and replace them with a unicast device. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide Should I do it if I dont want to watch directly on the same computer where DVBS cards are installed ? I want use only RS service and watch on 2-3 computers using http (vlc on computer or Ipod Touch) changes shown in attached info file - still no luck support.zip
Tjod Posted April 6, 2012 Posted April 6, 2012 Should I do it if I dont want to watch directly on the same computer where DVBS cards are installed ?You should first get it working on the pc with the recording Service. And if there everything works correct. How are the tuners connected to the lnb/multiswitch? Dose each tuner has its own cable.
V_G Posted April 6, 2012 Author Posted April 6, 2012 yes certainly - checked with DVBViewer on each as well as standalone Sat tuner. (all works fine)
V_G Posted April 6, 2012 Author Posted April 6, 2012 yes certainly - checked with DVBViewer on each as well as standalone Sat tuner. (all works fine) I found that FTA works
V_G Posted April 6, 2012 Author Posted April 6, 2012 Dear All, problem fixed after update DVBViewer and RS But I have additional question regarding unicast, can I watch scrambled TV using DVBViewer (as mentioned before) if yes where shoud I have Csard reader installed on client side or on server side ?
