DVBV 4.9.6 startup problems
majstang
After installing 4.9.6 I encountered a big issue and a small one. The small one was the script control message does flash by if starting the viewer with RS stopped.
I get a black screen whenever i start the viewer for both encrypted and fta channels. Sometimes it works getting picture, but most common not. If having RS started watching the loading bar (splashscreen when starting DVBV) the viewer window opens when 50% has been loaded. It seems something crucial are not getting initialized. If closing RS and starting the viewer then it loads 100% and then viewer window opens. If then starting RS no problems tuning a channel.
Edited by majstang
please explain again. in simple terms. :)
Failure every other startup.
Debuglog when it fails. No channel can be tuned in. Not even fta:s:
08.04.12 10:13:34.385 Start App ----------------------------------------
08.04.12 10:13:34.385 Start App DVBViewer.exe
08.04.12 10:13:34.385 Start App 4.9.6.0
08.04.12 10:13:34.440 SetThreadExecutionState 0x80000001
08.04.12 10:13:34.757 TDVBDevice.InitDevice Unicast Network Device
08.04.12 10:13:34.757 TDVBDevice.InitDevice Unicast Network Device 2
08.04.12 10:13:34.757 Device Check present
08.04.12 10:13:34.758 CheckDevicespresent start
08.04.12 10:13:34.758 DevicePath \\?\avc#digital_everywhere&firedtv_c#ci&typ_5&id_0#4f25000226871200#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{db365890-165f-11d0-a195-0020afd156e4}
08.04.12 10:13:34.758 DevicePath \\?\avc#digital_everywhere&firedtv_c#ci&typ_5&id_0#d111000226871200#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{db365890-165f-11d0-a195-0020afd156e4}
08.04.12 10:13:34.758 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{353e20b5-4b13-4db0-b84e-1e0000040000}
08.04.12 10:13:34.758 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{353e20b5-4b13-4db0-b84e-1e0000040001}
08.04.12 10:13:34.758 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{3ff44ee5-8547-402a-94f3-d40000020000}
08.04.12 10:13:34.758 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{3ff44ee5-8547-402a-94f3-d40000020001}
08.04.12 10:13:34.758 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{3ff44ee5-8547-402a-94f3-d4fe00020000}
08.04.12 10:13:34.758 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{3ff44ee5-8547-402a-94f3-d4fe00020001}
08.04.12 10:13:34.758 CheckDevicespresent end
08.04.12 10:13:34.921 DevicePath \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_10438410&rev_1003#4&2cb35cc7&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\rtlineinwave
08.04.12 10:13:34.921 DevicePath \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_10438410&rev_1003#4&2cb35cc7&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\rtmicinwave
08.04.12 10:13:34.921 DevicePath \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_10438410&rev_1003#4&2cb35cc7&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\rtstereomixwave
08.04.12 10:13:34.922 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a50000000000}
08.04.12 10:13:34.922 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{f3b951e7-8619-4ff3-91ca-030000000000}
08.04.12 10:13:35.044 LoadWindowDefs Loading WindowDefFile: C:\ProgramData\CMUV\DVBViewer\windowdef.xml
08.04.12 10:13:35.090 Settuner Start
08.04.12 10:13:35.094 TUCStreamThread Sessionstarted
08.04.12 10:13:35.094 TCMDSocketThread Sessionstarted
08.04.12 10:13:35.094 TfrmMain Allocate Unicast Network Device
08.04.12 10:13:35.094 Settuner Found usable hardware
08.04.12 10:13:35.094 TDVBHardware.SetTuner PMT: 307 - SID: 1012 - Freq: 482000 - Type: 0
08.04.12 10:13:35.094 Sendstr SETTUNER 0 482000 6875 0 0 3 0 0 4403 4147 307 1012 0 0 0 24 0 45 40999
08.04.12 10:13:35.094 Gotstr OK.
08.04.12 10:13:35.094 Sendstr1 ADDPID 18
08.04.12 10:13:35.094 Settuner End
08.04.12 10:13:35.103 Sendstr1 ADDPID 4147 4403 0 307 7987
08.04.12 10:13:35.104 AddAVCodecs VCodec: CyberLink Video Decoder (PDVD11), ACodec: CyberLink Audio Decoder (PDVD11)
08.04.12 10:13:35.145 VCodec CyberLink Video Decoder (PDVD11)
08.04.12 10:13:35.160 ACodec CyberLink Audio Decoder (PDVD11)
08.04.12 10:13:35.237 AddVideoRenderer Add EVR
08.04.12 10:13:35.334 EVR VideoProcessorMode {6E8329FF-B642-418B-BCF0-BCB6591E255F}
08.04.12 10:13:35.336 Used Filter 0: EVR Renderer
08.04.12 10:13:35.336 Used Filter 1: DirectSound: Digital Audio (HDMI) (High Definition Audio Device)
08.04.12 10:13:35.336 Used Filter 2: DVBV OSD-Source
08.04.12 10:13:35.336 Used Filter 3: Microsoft DTV-DVD Audio Decoder
08.04.12 10:13:35.336 Used Filter 4: CyberLink Video Decoder (PDVD11)
08.04.12 10:13:35.336 Used Filter 5: DVB Source
08.04.12 10:13:36.061 Gotstr CAMAVAIL 0
08.04.12 10:13:36.061 Gotstr OK.
08.04.12 10:13:36.062 Gotstr CAMAVAIL 0
Debuglog when it works:
08.04.12 10:17:17.042 Start App ----------------------------------------
08.04.12 10:17:17.042 Start App DVBViewer.exe
08.04.12 10:17:17.042 Start App 4.9.6.0
08.04.12 10:17:17.097 SetThreadExecutionState 0x80000001
08.04.12 10:17:17.423 TDVBDevice.InitDevice Unicast Network Device
08.04.12 10:17:17.423 TDVBDevice.InitDevice Unicast Network Device 2
08.04.12 10:17:17.423 Device Check present
08.04.12 10:17:17.423 CheckDevicespresent start
08.04.12 10:17:17.423 DevicePath \\?\avc#digital_everywhere&firedtv_c#ci&typ_5&id_0#4f25000226871200#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{db365890-165f-11d0-a195-0020afd156e4}
08.04.12 10:17:17.424 DevicePath \\?\avc#digital_everywhere&firedtv_c#ci&typ_5&id_0#d111000226871200#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{db365890-165f-11d0-a195-0020afd156e4}
08.04.12 10:17:17.424 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{353e20b5-4b13-4db0-b84e-1e0000040000}
08.04.12 10:17:17.424 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{353e20b5-4b13-4db0-b84e-1e0000040001}
08.04.12 10:17:17.424 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{3ff44ee5-8547-402a-94f3-d40000020000}
08.04.12 10:17:17.424 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{3ff44ee5-8547-402a-94f3-d40000020001}
08.04.12 10:17:17.424 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{3ff44ee5-8547-402a-94f3-d4fe00020000}
08.04.12 10:17:17.424 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{3ff44ee5-8547-402a-94f3-d4fe00020001}
08.04.12 10:17:17.424 CheckDevicespresent end
08.04.12 10:17:17.593 DevicePath \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_10438410&rev_1003#4&2cb35cc7&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\rtlineinwave
08.04.12 10:17:17.599 DevicePath \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_10438410&rev_1003#4&2cb35cc7&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\rtmicinwave
08.04.12 10:17:17.599 DevicePath \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_10438410&rev_1003#4&2cb35cc7&0&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\rtstereomixwave
08.04.12 10:17:17.599 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a50000000000}
08.04.12 10:17:17.599 DevicePath \\?\pci#ven_1131&dev_7231&subsys_362014c7&rev_aa#4&1d7623a1&0&00e2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{f3b951e7-8619-4ff3-91ca-030000000000}
08.04.12 10:17:17.727 LoadWindowDefs Loading WindowDefFile: C:\ProgramData\CMUV\DVBViewer\windowdef.xml
08.04.12 10:17:17.775 Settuner Start
08.04.12 10:17:17.778 TUCStreamThread Sessionstarted
08.04.12 10:17:17.778 TCMDSocketThread Sessionstarted
08.04.12 10:17:17.778 TfrmMain Allocate Unicast Network Device
08.04.12 10:17:17.778 Settuner Found usable hardware
08.04.12 10:17:17.778 TDVBHardware.SetTuner PMT: 307 - SID: 1012 - Freq: 482000 - Type: 0
08.04.12 10:17:17.779 Sendstr SETTUNER 0 482000 6875 0 0 3 0 0 4403 4147 307 1012 0 0 0 24 0 45 40999
08.04.12 10:17:17.779 Gotstr OK.
08.04.12 10:17:17.779 Sendstr1 ADDPID 18
08.04.12 10:17:17.779 Settuner End
08.04.12 10:17:17.788 Sendstr1 ADDPID 4147 4403 0 307 7987
08.04.12 10:17:17.789 AddAVCodecs VCodec: CyberLink Video Decoder (PDVD11), ACodec: CyberLink Audio Decoder (PDVD11)
08.04.12 10:17:17.830 VCodec CyberLink Video Decoder (PDVD11)
08.04.12 10:17:17.845 ACodec CyberLink Audio Decoder (PDVD11)
08.04.12 10:17:17.924 AddVideoRenderer Add EVR
08.04.12 10:17:18.025 EVR VideoProcessorMode {6E8329FF-B642-418B-BCF0-BCB6591E255F}
08.04.12 10:17:18.028 Used Filter 0: EVR Renderer
08.04.12 10:17:18.028 Used Filter 1: DirectSound: Digital Audio (HDMI) (High Definition Audio Device)
08.04.12 10:17:18.028 Used Filter 2: DVBV OSD-Source
08.04.12 10:17:18.028 Used Filter 3: Microsoft DTV-DVD Audio Decoder
08.04.12 10:17:18.028 Used Filter 4: CyberLink Video Decoder (PDVD11)
08.04.12 10:17:18.028 Used Filter 5: DVB Source
08.04.12 10:17:18.760 Gotstr CAMAVAIL 0
08.04.12 10:17:18.760 Gotstr OK.
08.04.12 10:17:20.905 Gotstr SIG 100
