Kaeptn Posted April 10, 2012 Posted April 10, 2012 my system: windows 7 pro 64bit Asus P8Z68 Deluxe, 2700k Asus 560 TI TT Budged S2-3200 with CI i am thinking about to purchase DVBViewer. does DVBViewer work with cryptoworks modul with this card? Quote
Kaeptn Posted April 10, 2012 Author Posted April 10, 2012 and whats about the remote control? is this functional with the viewer? tx!! Quote
dbraner Posted April 11, 2012 Posted April 11, 2012 and whats about the remote control? is this functional with the viewer? tx!! Don't forget to select "TT CI support" option when installing DVBViewer. Quote
Kaeptn Posted April 11, 2012 Author Posted April 11, 2012 hello, in the moment i am testing the demo, the ci modul works.. but i dont know how to use the remote..? Quote
BALOU Posted April 11, 2012 Posted April 11, 2012 the Remote works perfect. You must have the remoteplugin for Technotrend. You can this downloading from the members area. You must buy the DVBViewer pro to login in the members area. Quote
dbraner Posted April 12, 2012 Posted April 12, 2012 Instead of the TT remote plugin you can also use Eventghost with the TT plugin and the DVBViewer plugin. Quote
