Update if "Recorded Shows" doesn't work
cwood
Update of the "Recorded Shows" doesn't word. E.g. "Recorded Shows - Database - Delete Orphans" doesn't remove entries of shows which don't exist any more on the hard drive.
Checked in DVBViewer 4.9.5.1 and 4.9.6.0 (OS: Windows 7, 64-bit)
Any hints?
Clean the database in the Recording Service as well.
I cannot find a menu item to do that.
Where should it be located?
I tried the popup menu of the recording service and found either the Web Interface or the Service configuration. In none of these to options I can find something that cleans refreshes the database.
Webinterface -> Tasks -> Cleanup Recording database
