beheme Posted October 1, 2004 Posted October 1, 2004 yesterday i tried to record "the simpsons" for testing purpose. i marked it in the epg window and clicked "send to pvr".today i checked the file and was surprised to learn that the end (approx. 1 minute) is missing. the beginning is correct recorded, started 30 seconds before the opening scene. where is or could be the fault ? Quote
Guest Lars_MQ Posted October 1, 2004 Posted October 1, 2004 Well not a fault, but the station sometime transmit wrong or not exact times with epg. You should put some time before and after the recording, so everything gets recorded. You can use in Options-> epg the before and after times (in minutes) to adjust it. lars Quote
beheme Posted October 1, 2004 Author Posted October 1, 2004 thanks, that sounds good. i didn't know that there is this option. Quote
beheme Posted October 1, 2004 Author Posted October 1, 2004 hmm, i looked for it but i can't find that option. I have DVBViewer version 1.99 Quote
Guest Lars_MQ Posted October 1, 2004 Posted October 1, 2004 (edited) well you should update to v2.2. you can dowload the update from the membersarea with the key and password you got when you purchased DVBViewer. lars Edited October 1, 2004 by Lars_MQ Quote
Guest hackbart Posted October 1, 2004 Posted October 1, 2004 somhow the evil 1.99 version. i wonder why so many people are still using it Christian Quote
Hartwig Posted October 1, 2004 Posted October 1, 2004 They use it, because they won't get the pleasure of the new version. Or they have lost their user data. (Use the attachment and you'll see your data....) download UserData.zip Quote
Klausing Posted October 2, 2004 Posted October 2, 2004 nettes Tool. Ich habe mir erlaubt einen Link in der deutschen Linkliste zu setzen zu posten. Vielleicht hilfts ja dem einen oder anderen... Quote
Hartwig Posted October 2, 2004 Posted October 2, 2004 (edited) Ich hatte das eigentlich nur als Scherz gedacht, aber OK. Edit: Sorry for my german It should only be a little joke. But it's OK. Edited October 2, 2004 by Hartwig Quote
