Problems starting 4.9.6 does not recognize the last channel, to return to last channel should I start in administrator mode win7, also saves the recorder programming changes. I think this version has problems with the Windows 7 UAC.
substituted my version 4.9.5 by 4.9.6 and now I can return to the previous version. Is not possible to find 4.9.5 here? ¿old version achive? thnks.
(sorry for my english?
No but which anti virus software do you use?
avast 7 before, now mse, but no problem of antivirus, avast DVBViewer to be safe when analyzing the application. with version 4.9.5 this problem did not exist.
'll install using single user mode may well include the configuration files in appdata / roaming and not have to launch as an administrator.
you doing something wrong. greetings.
Disable Auto Sandboxing in avast for the DVBViewer.exe
xDD DVBViewer normally added to start sandboxing, that's not the problem I repeat it.
problem solved. I reinstalled choosing single user and now everything works fine. Thank you. greetings.
