ddichiera Posted April 18, 2012 Posted April 18, 2012 I'm trying to use TS Player to trim some satellite recordings but it doesn't recognise the DVB subtitles contained therein. They are definately there as I can see them with DVBViewer and VLC, but when I load the file up in TSPlayer, it just shows me the video and audio streams. Help? Quote
Derrick Posted April 18, 2012 Posted April 18, 2012 ..not implemented but the trimmed recording will contain the dvb subtitle stream if checked. Quote
Griga Posted April 18, 2012 Posted April 18, 2012 but it doesn't recognise the DVB subtitles contained therein. Increase Settings -> Search Depth, if they don't show up under "Available Streams". Quote
ddichiera Posted April 18, 2012 Author Posted April 18, 2012 Increase Settings -> Search Depth, if they don't show up under "Available Streams". That seems to have done the trick, it can now see them and they come up in light grey. Am trying a new "rip" now. Quote
ddichiera Posted April 18, 2012 Author Posted April 18, 2012 Ok, that worked, Thanks very much. Dominic Quote
