Timezone problems.
clashcityrocker
Never had a problem in the past, and I can't work out if it's because I updated to the latest version of DVBViewer and RecordingService, or if it's because in the UK we are now in BST.
I use my system to watch Formula One from RTL in Germany, and everything was out by an hour. I had to manually set the time difference to 60 minutes to get it correct, Auto didn't work.
I'm sure it used to work...
have you tried to stop the RS and delete the EPG.dat in the [your configuration folder]/config/ folder?
