Deterioration of HD Channels
Djibril
First of all, hello
My problem continues for about 3 weeks. Which codec, renderer 's I tried again, a negative result: (
We gotta make a video and watch pictures and would like a little ..
My codec
System.
activeted Aero and set VSync by Aero...
I have Aero active. But could not figure out what Vsync: (
Excuse me. I found, I believe. But the result was the same, and distortion is still there: (
Edited by Djibril
  • 7 months later...
I have exactly the same problem!
Is there any help?
Ich habe genau das gleiche Problem.
Gibt es mittlerweile eine Lösung?
And maybe disable hardware acceleration or update the graphic card driver.
From Djibril's screenshot the problem may be they do not have hardware acceleration enabled in LAV (CUVID for NVidia or DXVA/2 for others).
EDIT: I see the video card is ancient Radeon X1550, ideally you should upgrade it.
Edited by dvbrewer
  • 2 months later...
Hello.
I have the same issue since updated to w8 professional 64b from 32b versión. In 32b version all works fine, but i need 64b o.s. to use my new 3tb hard disk.
I have a GA-945P- DS3 motherboard with a nvidia 8600GT (all drivers and firmware fully updated). I tried with a lot of codecs and render combinations and nothing works.
Any idea?
thanks.
