cundogg Posted April 29, 2012 Posted April 29, 2012 hello. could anyone help me out? i am looking to turn off the channel names in the OSD epg and just use the channel logos instead. the names are taking up more room than the logos at the minute. any help would be appreciated Quote
Tjod Posted April 29, 2012 Posted April 29, 2012 You have to change all OSD-skin pages from the skin you are using. http://www.DVBViewer.com/lars/skineditor.zip http://www.DVBViewer.tv/forum/topic/40078-dvbviewerskinner-ein-osd-skin-editor/ Quote
cundogg Posted April 29, 2012 Author Posted April 29, 2012 thanks for the quick reply. I was also wondering if there was a one button press to view a program when your are browsing through the tv guide like the way sky digital lets u press the select button to instantly view the current program on the tv guide. Quote
tomas.jurksas Posted April 30, 2012 Posted April 30, 2012 If I understand correct it's a Green button (Show EPG) in Favorites or channel list. Quote
themaster1 Posted May 3, 2012 Posted May 3, 2012 There is the feature called "osd favourites list" which does exactly this, i use it daily and is more useful/easy to use (with a remote) than the Timeline Epg in my eyes Quote
