barrygreybeard Posted May 4, 2012 Posted May 4, 2012 Having installed V1.9.6 of the Recording Service I have 2 problems when using the web interface with Firefox v12.0 Channel EPG does not show the program list, just the tree to the left The setting under "Configuration - Start Page" is not saved, setting it to "Timer" still opens the "Channel EPG" page even though Timer is still listed in the "Start Page" box. There may be others but I didn't get further than that using the Web interface. I have had many previous versions of Recording Service installed and all worked fine under Firefox, expect this one. I installed it over the previous version Barry
Lars_MQ Posted May 4, 2012 Posted May 4, 2012 Just do a reload of the page in the webbrowser to force the webbrowser to download all files again instead of using the cached ones.
barrygreybeard Posted May 4, 2012 Author Posted May 4, 2012 thanks Lars that worked, should have thought of that myself!
