gawcio90 Posted May 4, 2012 Posted May 4, 2012 (edited) Hello, I've got a problem. When I try press STOP button it's not working. Is this a bug? Regards gawcio Edited May 4, 2012 by gawcio90 Quote
gawcio90 Posted May 4, 2012 Author Posted May 4, 2012 If you click on this button, playing should stop. But nothing happens. Quote
Lars_MQ Posted May 4, 2012 Posted May 4, 2012 Well obviously nothing stopable is playing otherwise it would stop. Quote
gawcio90 Posted May 4, 2012 Author Posted May 4, 2012 In my case I playing ordinary TV program. I have to stop playing with the key. I thought that this button can stopping everything. Quote
Griga Posted May 4, 2012 Posted May 4, 2012 I thought that this button can stopping everything. The "View -> Audio/Video disabled" menu item does exactly what you want. It sets TV/Radio playback to the stopped state and back to the running state. The stop button that one expects to have this function does nothing on TV/Radio playback (*), but without signalling that it is disabled. On the other hand, it takes effect on file playback, and the "View -> Audio/Video disabled" menu item is disabled (visibly in this case). It is hard to understand the logic behind it, if there is any... if I would encounter this behaviour as someone being new to DVBViewer, I would for sure regard it as bug. (*) Just investigated: It does something, but only if timeshift recording is going on. It stops recording or deletes the timeshift file, if recording is already stopped. Maybe that's why there is no hint for the stop button when you hold the mouse cursor on it. It would become a long story. Quote
gawcio90 Posted May 4, 2012 Author Posted May 4, 2012 Thanks, I've already seen! The "View -> Audio/Video disabled" This method it is not proper for me because program still using CPU resources. Another way is the "View ->Close Graph" - Much better for my. Thank you! Quote
