troubles from mexico
ilomsa
hello im from mexico san luis potosi exactly y bought a new sky star 2 pci card to receive dvb channels the problem is that i alway got an red icon next the clock on windows me i have a new lnbf from chaparral its digital ofcourse but im still in the red thing i put a few transponders based on lyngsat charts but i still can get anything im using version 2.2.8 2.2.5 and 2.2.5 drivers and still the samething
the card have a jumper i dont know for what is this do you know???
the card say skystar2 rev 6.28 and has two yellow marks the device is burned out ???
are other brands more easier to install i tried with a broadlogic 2030 but i cant get more than 60% of signal anyway i cant get nothing im using a piii 500mhz 64 mb ram and a 20gb hdd the video card is the sis pci with 32mb video the machine is only for the pci card i use other computers to do other things well i hope to get an answer for you this forum is from europe ??? if it is hello to all ue and hasta luego desde mexico. thankz
Hi!
If you have the possibility you could try to connect the lnb to an analogue receiver to see whether the dish is pointing to the right direction and lnb and cable are properly installed and working fine.
What do you mean with 2 yellow marks???????
AFAIK you should leave the jumper as it is.
Make sure that u are tuning a station which is on the satletie that your dish is pointing at.
Hello there,
Are the yellow marks in the device manager section? if this is true it could mean that two devices are not being recognized by windows or the drivers are not properly installed.
The red icon is an application that you can safely shutdown; SkyStar 2 uses it when you have Internet by satellite, just right click on it and select "Exit". It is advisable that you remove it from the Startup section going to:
"Start/Programs/Startup" and right clicking on the red icon select "delete", that way it will not run again when you reboot or shutdown your machine.
Hola de nuevo,
El icono rojo es una aplicación que se usa cuando estas subscrito a un
Servicio de internet por satelite, muy comun en Europa, puedes apagar
Esa aplicación porque no es necesario para ver television via satelite, puedes quitarla tambien de la sección Starup o inicio de Windows para que no vuelva a aparecer, solo asegurate de NO desinstalarla.
Si las marcas amarillas estan en Device manager quiza se trata de algun dispositivo mal instalado.
Otra cosa, no puede ayudarte con los satelites FTA, te aconsejo que vayas a los foros americanos usando un alias, ellos podrian ayudarte, recuerda que este foro es para los Europeos, la configuración es un tanto diferente.
Buena suerte
in harware manager? This ist not good. there is something wrong by installation of the drivers !
Reinstall drivers.
HELLO AGAIN THANKS FOR THE HELP THE DOT MARKS ARE IN THE BACK OF THE CARD THIS CARDS SAY SKYSTAR2 I TRIED WITH ONE THAT SAID SKY2PC IT DOESNT HAVE THE YELLOW MARKS ON ITS BACK ITS JUST TO DIFFERENCE BETWEEN ONE AND ANOTHER AND YOU CAN DISTINGUISH BUT THANKS THE PROGRAM WITH THE RED ICON ITS NOT NECESARY THEN OKAY THANKS BUT WHEN I RUN DVBViewer TECHNISAT EDITION IT START SCANNING THE SAT BUT CANT FIND ANYTHING THE SATELLITE IM TRYING ITS GALAXY 10R YOU CAN SEE THE CHANNELS AVAILABLE ON THIS SAT AT WWW.LYNGSAT.COM THEY ARE MANY IN KU BAND MY DISH IS A 75 CM SOLID DISH AND A UNIVERSAL KU LNB FROM CHAPARRAL ILL KEEP TRYING UNTIL I SEE SOMETHING THESE TYPE OF CARDS ARE NO USED HERE IN MEXICO BUT IM TRYING TO MAKE IT WORK TO COMERCIALIZE IT HERE IT COULD BE A GREAT BUSSINESS HERE I ALSO HAVE AN ANALOG SYSTEM ON C BAND AND ITS STILL RUNNING ON US SAT AND PROGRAMS BY THE WAY CAN I USE MY BIG DISH ITS NO SOLID FOR DIGITAL C BAND IF I CAN DO I JUST NEED A DIGITAL C BAND LNB AND I CAN TEST WITH THE SKYSTAR2 WELL THANKS A LOT AND I HOPE TO KEEP TALKING WITH YOU BROTHERS HASTA PRONTO!!!
open Scan Tab and and write as sattelite "test" and scan again. It takes some time !!! Because it scans in small steps.
After this you schould have some stations.
An other question: Do you have some hubs or switches between your SS2 and the LNB? Or have you a direct connection from SS2 to LNB?
Steffen
