MKV and Bluray
krasno
hello
Just in case someone can use this:
..after a several evenings with serious work and and got grey hair I found this "easy" solution to get subtitles on MKV recordings made by MakeMkv from Bluray movies
It works here, but no guarantees on other set-up's :)
download from DVBViewer's homepage, Members section http://DVBViewer.com/en/index.php : postprocessor
downlaod haali matroska: http://haali.su/mkv/
download DirectVobSub: http://www.free-codecs.com/download/directvobsub.htm
downlaod CCCP ffmpeg: http://www.cccp-project.net/
download LAV codecs here: http://www.codecs.com/download/LAVFSplitter.htm
use LAV videodecoder for all types decoders in Settings/Options/Directx in DVBViewer
install DA-player
http://www.digiarty.com/
go into haali from start menu in Windows:options/compability/ and: load Vsfilter =YES
restart PC !!
if it don't work then don't blame me...get drunk... smash your PC and buy a bluray stand-alone player.. and forget about using hardiscs and HTPC..
Ps I'm absolutely not sure DA-player is nesseary, BUT it can play back both MKV and Bluray disc's directly, with any further adjustments than downloading it,
and you know..I'm too lazy to delete it, just to see if MKV files works without it or not
cheers! and good luck, you will need it ..
