aydan Posted October 5, 2004 Posted October 5, 2004 Hi, how can you remove key assignments in the controls tab? Quote
Guest Oliver Posted October 5, 2004 Posted October 5, 2004 Yes, just assign the same key again. Bye, Oliver Quote
Gioxy Posted October 5, 2004 Posted October 5, 2004 (edited) Uhmmm... I agree with Oliver; but if you want just remove (read it "clean") a key assignement with the own popup windows, there are no "direct" way... You can: • assign the key you want to clean (e.g. "G") to a already "used" function (e.g. "Channel list", normally "K"); • this make the key disappear from the place you want clear*; • reassign the old key to the function (= "K" to "Channel list")... * It seem that there is a little bug in checking the "Pause" key assignation (normally "spacebar"): also if you change it, the "Pause" key can be also assigned to another function... Cheers Gioxy Edited October 5, 2004 by Gioxy Quote
Guest Oliver Posted October 5, 2004 Posted October 5, 2004 I agree with Oliver; but if you want just remove (read it "clean") a key assignement with the own popup windows, there are no "direct" way... If, for example, the key A is assigned to the pause-function, you can remove this assignment by assigning A again with the popup window. Bye, Oliver Quote
Gioxy Posted October 5, 2004 Posted October 5, 2004 you can remove this assignment by assigning A again with the popup window. Gosh! I haven't noticed yet... pretty unusual solution, but really quick! Good to know... thanks Oliver! Gioxy Quote
