Hartwig Posted October 5, 2004 Posted October 5, 2004 (edited) The Problem seems to be WinDVD. reinstall it and test it again. If you use the TE Version, try to use the last patch http://www.DVBViewer.com/download/patch.zip Edited October 5, 2004 by Hartwig Quote
Simon82 Posted October 5, 2004 Author Posted October 5, 2004 The Problem seems to be WinDVD. reinstall it and test it again.If you use the TE Version, try to use the last patch http://www.DVBViewer.com/download/patch.zip I've solved the problem... thanx for the help!!! Quote
