Riodda Posted May 17, 2012 Posted May 17, 2012 Hi, i've installe DVBViewer on Windows 7 64bit on an I7. I had a WinTV-Nova-S-USB2 Value that was working fine, after a month it stopped working, hardware was detected but no sintony e no signal also with other software, i've checked the LNB and with my Dreambox all was ok, so i thought the card was dead, then i've purchased a Terratec Cinergy S2 USB. With this brand new card i have the same issue, so i'm very puzzled. In attach the support.zip i really hope you can solve my problem. In attach support.zip and system info. Regards. support.zip sysinfo.rar Quote
Derrick Posted May 17, 2012 Posted May 17, 2012 I can't see any obvious setup error. Try to scan the transponderlist with TransEdit. Did you connect the same cable to your dreambox? Quote
Riodda Posted May 17, 2012 Author Posted May 17, 2012 I can't see any obvious setup error. Try to scan the transponderlist with TransEdit. Did you connect the same cable to your dreambox? Dreambox is disconnected, the cable is the same, i will try to scan the transponder list but it's puzzling that all the software are dead, progdvb DVBViewer WinTV7....quite weirt... Quote
Riodda Posted May 17, 2012 Author Posted May 17, 2012 When i scan frequency rage i have this view I have tryed al the config of the disec (i have Hotbird on A and astra on B, but before i was fine with No Disec since i don't care about astra channels). Quote
