DVB S2 - SRF
saturnin
Hello,
I'm trying DVBViewer Pro Demo - Hauppauge 5500 and need to test SRF HD. I have updated the transponder file 0130.ini with the correct entry for SRF - RTS HD:
14=10971,H,29700,23,S2,8PSK
doing a scan, I still cannot found any new channels.
PS: for example RSI HD use another transponder and everything is working fine for this channel using DVBViewer Demo.
Best Regards
check pilot symbols "on"
14=10971,H,29700,23,134
Hello,
Thank you, I was so able to scan this transponder, but still cannot get an image, for example for "SF1 HD (deu)" but "RSI LA 1 HD (ita)" is working fine ...
Both "RSI LA 1 HD (ita)" and "SF1 HD (deu)" use H.264, CI + Viaccess CAM + SAT ACCESS Swiss card but are on different transponder (SF1 HD on 10791, RSI 1 HD on 11526)
Best Regards
Topic moved. Please post in the correct forum section.
  • 3 weeks later...
