xeondk Posted May 26, 2012 Posted May 26, 2012 After install of DVBViewer v4.9.6 i recive: "User Data Error 128. Please use Keytool.exe to enter correct data" every time i try to open DVBViewer. I have searched and tried all the solutions i could find i this forum and on different machines but with same result. I have no antivirus running and firewall is disabled. Clean install gives same result even with a clean windows 7 install. The keytool shows the correct checksum when i enter my userdata so they should be ok. I also tried to manually copy the dvbvkey but still no luck. I don't know what else i can do so I hope someone can help me. support.zip Quote
Griga Posted May 31, 2012 Posted May 31, 2012 The error suggests that something is wrong with the username. It doesn't seem to match completely. If the checksum is correct, wrong user data are quite unlikely, but not impossible. So please check it again. If you can't find a solution, write to the address on this page. Quote
xeondk Posted June 1, 2012 Author Posted June 1, 2012 Thanks. I will try to write to the lost and found. Quote
