Mr. Man-wai Chang Posted May 28, 2012 Posted May 28, 2012 (edited) Does Recording Service use the "-thread" option of FFMpeg to speed up transcoding? Could I configure the way how RS calls FFMpeg via RS's user interface? Edited May 28, 2012 by Mr. Man-wai Chang
Lars_MQ Posted May 28, 2012 Posted May 28, 2012 Yes the threads parameter is set and no, you have to edit the ffmpegprefs.ini or the iphoneprefs.ini to change the parameters. And you do it at your own risk.
