What did i do wrong?
Reconos
Heya Fellow Dvbviewers!
I've had my DVBViewer setup running for almost half a year now without any problems until 2 days ago!
Here is what happened:
I receive my television thru my fiber provider, and they tend to update their IP addresses on the TV channels 2 times each year.
I used transedit to get the new ip's and got it running on my main computer.
Here comes the tricky part!!
I have a laptop in another room, that suddenly can't connect to my recording service, but the 2 other laptops I have, connects without any problems.
I tried updating to newest version of DVBViewer on the faulty laptop, re-entered the username/password and IP address, but it still fails to connect?
If I use the IP address of my "TV Test Server" it connects without problems.
Anyone got any idea about what I’m doing wrong?
Kind Regards
-Reconos
Is it only DVBViewer that cannot connect? Are you able to open webinterface, or ping the IP of the service?
It's only DVBViewer, Web interface works without problems. Tried with my Admin login, which suddenly works, but my guest login still only gives me "Failed". I've re-entered the guest password in the settings, so this shouldn't be a problem.
