buttonsNI. Posted June 7, 2012 Posted June 7, 2012 when recording from the service and after setting "all audio tracks" the recording does not record ac3. with same setting inside inside the DVBViewer the recording has ac3 why?
Derrick Posted June 7, 2012 Posted June 7, 2012 FTA or scrambled? In case of the latter which CI-module? I get all audio tracks
buttonsNI. Posted June 7, 2012 Author Posted June 7, 2012 the problem is solved by repositioning the channels scan (audio stereo/nar and ac3) so that the ac3 channel appears first in the channel list. it also means that the tick for recording "all audio tracks" within the service isn't working if the stereo/nar audio appears first in the DVBViewer channel list
Derrick Posted June 7, 2012 Posted June 7, 2012 you didn't answer my question ..anyway, I can't reproduce this behaviour
